How do I wire the light bar button?
Discussion in 'Lighting' started by Early B., Sep 1, 2020.
  1. Sep 1, 2020 at 4:10 PM
    Early B.
    Early B. [OP] Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    I purchased and installed a light bar along with this wiring harness: https://www.amazon.com/gp/product/B076C5HV59/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    And this light bar button: https://www.amazon.com/gp/product/B0117B1J3W/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
    The light bar button has the wire configuration as shown in the image below.
    After snipping off the power button, the wiring harness has three wires -- black, red, and yellow.
    How do I hook up the black, red and yellow wiring harness wires to the green, black, and 2 red wires from the light bar button?
    Thanks.
  2. Sep 1, 2020 at 4:21 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Suggest you go through a relay, as your light bar button instructions hints - Red 1.
  3. Sep 1, 2020 at 5:16 PM
    Early B.
    Brad
    metro Atlanta
    The wiring harness has a relay, but which wire is it -- red or yellow (I'm assuming it's not the black wire)?
  4. Sep 1, 2020 at 5:21 PM
    rnish
    Tacoma 2nd gen
    The “button“ should activate the contact coil on the relay. This will close the relay contacts. Allowing the lights to draw its power from the relay.
  5. Sep 1, 2020 at 5:26 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    He cut the "button" off.
  6. Sep 1, 2020 at 5:30 PM
    81shark
    81shark Well-Known Member
    That green wire seems like it would be useful.
    Spanky3412 likes this.
  7. Sep 1, 2020 at 5:31 PM
    YF_Ryan
    Kent, WA
    After looking at images and closeups on the Amazon links, i BELIEVE:
    Green 1 should go to your Red wire
    Red 1 should go to yellow wire
    I believe these two just control the light up function of the rocker switch.
    Red 2 should go to keyed power
    Black connects to ground.
  8. Sep 1, 2020 at 8:09 PM
    Early B.
    Brad
    metro Atlanta
    Let me see if I got this right:
    BUTTON HARNESS
    Black to Black
    Red 1 to Yellow
    Green to Red
    Red 2 on button -- I can eliminate because I don't want it to light up with the dash lights.
    Is this correct?
  9. Sep 2, 2020 at 7:01 AM
    YF_Ryan
    Kent, WA
    The back is not needed at all, as it is the ground for the light in the switch.
    The below is all you need as the switch is simply connecting the Yellow and Red wires from the Harness. They could technically be Red 1 to Red and Green to Yellow, it wouldn't matter. BUT, I'd suggest keeping it as the pictures/instructions show.
    Red 1 to Yellow
    Green to Red
  10. Sep 2, 2020 at 12:53 PM
    Early B.
    Brad
    metro Atlanta
    Great!! I really appreciate your help.
  11. Sep 2, 2020 at 1:15 PM
    YF_Ryan
    Kent, WA
    No problem. I'm lucky enough to have a local buddy that's been a huge help teaching me about wiring... and most everything else truck/off road related that I need to know!
  12. Sep 2, 2020 at 3:20 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Unless of course you want the switch to light up.
  13. Sep 2, 2020 at 4:43 PM
    YF_Ryan
    Kent, WA
    Which is exactly how he wanted it :thumbsup: errr... didn't want it? He did NOT want it to light up, lol.
  14. Sep 2, 2020 at 5:58 PM
    Too Stroked
    Tom
    Ahhh, sorry about that chief. Missed that part.
    YF_Ryan[QUOTED] likes this.
  15. Feb 17, 2021 at 9:22 AM
    mwrood
    mwrood Well-Known Member
    2021 Voodoo Blue TRD Premium Sport
    Out of curiosity, what light bar did you get? I won’t use it often, but I was thinking about getting one for my hood scoop and one for my grill, but don’t want to spend an arm and a leg.
  16. Feb 17, 2021 at 7:48 PM
    Early B.
    Brad
    metro Atlanta
  17. Feb 17, 2021 at 7:53 PM
    mwrood
  18. Feb 21, 2021 at 8:23 AM
    Early B.
    Brad
    metro Atlanta
    The light bar is mounted on my after market grille.
    mwrood[QUOTED] likes this.
