How do put xbox 360 in Tacoma.?
Discussion in 'Audio & Video' started by CristianTRD, May 24, 2012.
  1. May 24, 2012 at 7:26 PM
    CristianTRD
    CristianTRD [OP] Well-Known Member
    Cristian
    San Antonio, Texas
    '08 Silver Tacoma Off Road TRD
    I've seen a couple of people put in there xbox's in there Tacoma's. I was wondering how you would do this and if there was a writeup somewhere. I searched but could find any here. I've got a double din H/U, I just wanted to know how simple or complicated it was to do it.
  2. May 24, 2012 at 7:28 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
  3. May 26, 2012 at 1:41 PM
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    Assuming that your DDin head unit has an auxiliary video input, It really isn't that complicated.
    I would use a minimum 500 watt 12v inverter with a properly fused dedicated circuit from the battery. You can probably find a decent inverter with a 12v turn on wire that you can tap off of an accessory power source or the turn on signal from your head unit.
    From there, you just have to figure out where you want the x box to sit in the truck and make the rest of your wire runs.
  4. May 26, 2012 at 1:46 PM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
