How do some run this tire size without a CMC?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigGilly444, Apr 4, 2022.
  1. Apr 4, 2022 at 7:39 PM
    #41
    BigGilly444
    BigGilly444 [OP] Well-Known Member
    Eric
    19 TRD Sort
    I may try them tomorrow and see
  2. Apr 4, 2022 at 7:46 PM
    #42
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Those wheel won’t work wo the spacer. That wheel with the +30 is a 6” + bs.
  3. Apr 4, 2022 at 7:48 PM
    #43
    BigGilly444
    Eric
    19 TRD Sort
    Huh? The stock wheel is same offset‍♂️ and I ran without spacers and were fine. Just can't fit wild peak 285 70s
  4. Apr 4, 2022 at 7:50 PM
    #44
    gotoman1969
    The stock wheel is only 7” wide. The factory bs with a +30 is approx 5” bs. On the Tacomas 5.5” bs is about max you can run.
  5. Apr 4, 2022 at 8:09 PM
    #45
    BigGilly444
    Eric
    19 TRD Sort
    So my black rhinos are +30, 9.5" wide with 1.5 in spacer making it I guess -1.5" bs. This dang math story problem gives me a headache
  6. Apr 4, 2022 at 8:11 PM
    #46
    gotoman1969
    Sending a pm
  7. Apr 4, 2022 at 8:15 PM
    #47
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Sport is 17x7.5 +30mm with 5.5" backspace.
    A 9.5 +30mm has a 6.5" backspace.
    With a 1.25" spacer it would have a 5.25" backspace.
    gotoman1969 likes this.
  8. Apr 4, 2022 at 8:20 PM
    #48
    gotoman1969
    Op. All things being equal. Both wheels same offset. Your 9.5 is already sitting out 1” (since the sport wheel is 7.5”) further over stock. Then you pushed it out another 1.25” with the spacer.
    hiPSI, 908tacoma and splitbolt like this.
  9. Apr 4, 2022 at 9:07 PM
    #49
    BigGilly444
    Eric
    19 TRD Sort
    So it should work? Lol
  10. Apr 4, 2022 at 9:12 PM
    #50
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Get your alignment set a 3-0-0. 3* castor will shove your tire forward .75”-1”
  11. Apr 4, 2022 at 9:14 PM
    #51
    BigGilly444
    Eric
    19 TRD Sort
    How can anything move forward without adjustable UCAS?
  12. Apr 4, 2022 at 9:44 PM
    #52
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    The bulk of your caster comes from the lower cams which is what moves the tire away from the cab mount. UCA just allow adjustment to caster on compression and it’s not a lot.
    Need to drop the spacer and your wheel is too wide anyway. But to each their own.
    908tacoma and CaptainBart45 like this.
  13. Apr 4, 2022 at 9:57 PM
    #53
    picturethis
    picturethis Well-Known Member
    Billy
    Issaquah, Wa
    2001 and 2016 Silver Tacoma DCLB TRD Sport
    BAMF Grille CBI Sliders Victory4x4 roof rack Cali Raised fog lights FNFX wheels Falken Wildpeaks tires
    I had a CMC
    Running 285/70/17
    0 offset, still rubbed, had to cut, hammer, and now I rub on special occations :) do have spacers!!
    CMC doesn't mean no rubbing
  14. Apr 4, 2022 at 10:06 PM
    #54
    BigGilly444
    Eric
    19 TRD Sort
    Wheels are to wide?
  15. Apr 4, 2022 at 11:22 PM
    #55
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Listen to JoeCOVA.
    Plus you don't have to do everything you want in one step. Take things slow. I, somewhat like you, did not know what I was doing so I simply changed to 255/85R16 (33" narrow) from the stock tires on the stock OR 16" rims. Used the LCAs to move the assembly forward and had it aligned. Have a bit of rubbing in the front, none in the back at the body mount. Was able to reinstall my factory mud flaps as well, with the chop your mud flaps are gone, if you have them.
  16. Apr 5, 2022 at 5:45 PM
    #56
    JVL1985
    JVL1985 Well-Known Member
    2019 Tacoma Double Cab, short bed,4x4, v6, TRD Off-road
    I'm considering the exact same tire size. What lift are you running? Do you feel the transmission " gear searching"? How did the ride change?
    I'm getting ready to install fox 2.5 coilovers which should give me about a 2" lift. Just trying to figure out the best tire size to avoid rubbing and having to re-gear it.
  17. Apr 5, 2022 at 5:46 PM
    #57
    BigGilly444
    Eric
    19 TRD Sort
    You should regear even at stock. I regeared and ride is totally enjoyable now
    Kolter45 likes this.
  18. Apr 5, 2022 at 6:31 PM
    #58
    Toycoma2021
    I have no lift, that is what is great about this tire size increase as an interim step. I did put on those adjustable Upper Control Arms whose name I cannot think of at this time. I was told the UCAs were not necessary at my alignment, but I like to start slowly and build from there, since I was fooling around with the front and control arms are so critical, I just thought I would give myself some future options with their addition. There is a very slight rubbing on the front bumper/fender which could be eliminated by another adjustment of the lower control arms and another alignment. I agree with BigGilly444 on regearing, I will be doing the same when I get some armor on the vehicle. Until that time it does not go off road at all, at least until I get some rock sliders installed of my own design. SPC control arms and BFGoodrich KA3 tires.
    Ride changed by noise from the KA3 tread and sponginess of the rubber used in these tires - steering mostly effected. I am told that is a "feature" of these tires, the tires won't last a year with my driving and perhaps in that time I will have decided what my next step(s) will be. Transmission searching may have gotten worse, but I am not that particular at this point as I do know I will be regearing.
  19. Apr 5, 2022 at 6:36 PM
    #59
    BigGilly444
    Eric
    19 TRD Sort
    You will love it once you regear
  20. Apr 5, 2022 at 6:38 PM
    #60
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    The offset is the same as stock but the wheel is 1.5” wider than stock so the numbers are totally different.
