How do those 4cylinder Tacos run?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NC tundra, May 21, 2017.
  1. May 22, 2017 at 4:03 PM
    #61
    T4RFTMFW
    T4RFTMFW Well-Known Member
  2. May 22, 2017 at 4:14 PM
    #62
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    If I was shopping for a 3rd gen tacoma right now I would for sure look at the utility package 2.7 4x4 MT. The 2.7 engine is made in japan i think?. There is one for $24k (!!!) at my local dealership. Add someone's throwaway tow hitch and a 60$ curt 4-flat trailer plug. The 2.7 is Tow rated at 3500lbs (around there I think) I towed 5000 lbs once with my v6 2007 and it was scary the way it shoved the truck around. Don't think I would exceed the rating on the 2.7 with what I do.
  3. May 23, 2017 at 9:22 AM
    #63
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Also, overseas the Hilux with the same 2.7L is rated to tow 2500 kg which is roughly 5500 lbs. For what it's worth.
    IronPeak[QUOTED] likes this.
  4. May 23, 2017 at 3:31 PM
    #64
    NC tundra
    NC tundra [OP] Member
    2014 Tundra 4x4 Crew
    Great stuff and info guys, Is the 4 cylinder auto any good???
  5. May 23, 2017 at 3:39 PM
    #65
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Actually it's the 2016+ 2.7L engine that got dual VVTI but not just that the 5spd manual was also overhauled with a triple synchronized and lower first gear (NICE!) and taller overdrive or 5th gear so good to see the 4cyl got some love!
    Just wouldn't want it for towing
    Diablo169[QUOTED] likes this.
  6. May 23, 2017 at 3:39 PM
    #66
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    My initial test drive was a 4cyl auto SR5. I thought it drove great, but I am a 3 pedal guy thru and thru so I bought the stick.
  7. May 23, 2017 at 3:39 PM
    #67
    TireFire
    Olympic Peninsula
    No
  8. May 23, 2017 at 3:40 PM
    #68
    TireFire
    Olympic Peninsula
    Different clutch maybe?
  9. May 23, 2017 at 3:44 PM
    #69
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Yes , I love mine
    CusterFan likes this.
  10. May 23, 2017 at 3:47 PM
    #70
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Hilux has 6 speed mt with 2.7, so maybe? From what I can gather tow rating is more to do with tow package, as v6 3rd gen tacomas WITHOUT tow package have the same 3500 lb rating as the 4 cyls
  11. May 23, 2017 at 3:58 PM
    #71
    TireFire
    Olympic Peninsula
    6spd?!? Do tell! Hope it's not the same POS they stuffed behind the second gen 4.0
  12. May 23, 2017 at 4:00 PM
    #72
    TireFire
    Olympic Peninsula
    And that's just safety shit because mechanically they're the same trucks otherwise. Tow package is just a stronger hitch receiver, 7 wires instead of 4 (for trailer brakes and battery) and bigger alternator so it can all be added pretty easy. On tundras on the other hand tow package also means lower gears
    RocTaco[QUOTED] likes this.
  13. May 23, 2017 at 4:08 PM
    #73
    Hiluxski
    Ventura California
    Just curious what you don't like about yours ? , The 4.30 gears with this 2.7 , in the automatic is a win. I think it's a great combination.
  14. May 23, 2017 at 4:10 PM
    #74
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Good to know, I thought I heard some 2nd gen guys saying that changed happend for the 15' model year, but wasn't really talked about.
  15. May 23, 2017 at 4:10 PM
    #75
    TireFire
    Olympic Peninsula
    I don't have one and I didn't know the third gen auto got 4.3 diffs. I drove a friends second gen 2.7 auto for a few hours on a road trip some time ago and thought it sucked. Also was terrible on gas all loaded up
  16. May 23, 2017 at 4:13 PM
    #76
    TireFire
    Olympic Peninsula
    Hey OP, to get this back in track I think you could save yourself some serious coin picking up a slightly used 4cyl because they don't have the same resale value. Most people want a V6 or V8 in a truck and this 2.7 is greatly underrated. Should do for your kiddos first car
  17. May 23, 2017 at 4:16 PM
    #77
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Yeah buddy Utility package is where the f*** it's at. Walked into my Toyota dealer and walked out with my little 4 banger for 22k.
    My understanding is that the 2.7's are still made in Japan.
    Good point. it's worth mentioning that 2.7 autos have 4.3 gears from the factory, and also, very important, it is NOT the same 6 speed automatic that is mated to the V6 models. Close, but different in a number of internals. (# of clutch packs and stuff are different, same ratios though)
    Most of the people hating on the 3rd gen 2.7 have not driven one!
    Mine with the LCE header kicks absolute ass. It does suffer from pronounced altitude sickness (get up to 8,000+ feet and yeah she's a bit wheezy) but otherwise the Dual VVTi gives you a really solid powerband around town and on the highway, returns great mileage (23 MPG highway with a lift and A/Ts...) and is pretty legendary in the reliability column.
  18. May 23, 2017 at 4:22 PM
    #78
    sogafarm
    sogafarm Well-Known Member
    GA
    2012 tacoma reg cab spruce mica
    31" Falkon wild peak AT's, fat bobs lift, mud accents
    I have the 2012 2.7 auto in 2wd reg cab with the 3.58 rear. Have had zero problems. Came new with 215/70/15's and had plenty of power. Of course had to put lift and 31's on and power suffered, but does fine for my needs. Mpg stock averaged 22, lucky to get 20 mpg now. Mostly get 18 mpg all around.
    The 4wd's came with 4.10, so I can imagine that would be the best set up. X2 on the manual trans being the better choice.
    InfernoTonka likes this.
  19. May 23, 2017 at 4:32 PM
    #79
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Exactly. Getting the load rolling is only a small part of towing. Proper loading, leveling and driving is more important than how many cylinders you have
  20. May 23, 2017 at 4:36 PM
    #80
    Hiluxski
    Ventura California
    Yea , that would explain your "no" You don't own and have never have driven the vehicle we're discussing and feel qualified to give a negative opinion. Cool . I can't figure out how the 2.7 auto or the third GEN Tacoma for that matter gets a bad rap , I can't figure it out. Lol
    sucra likes this.
