How do u move headlights down
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tiresize33, Oct 23, 2011.
  1. Oct 23, 2011 at 6:11 AM
    Tiresize33
    Tiresize33 [OP] Well-Known Member
    oregon
    Toyota
    50 series flowmaster all way from the cat duals, afe intake, HID 6K, debaged, leer canopy, roof rack and spare, back up lights, clear protectint on front of truck, tinted windows, weather tech floor mats, amp steps, 6in procomp coil over, badass stereo
    I got a 2011 tacoma how do u aim tghe lights down, i put a six lift on it.... Plz if u could show pictures or video
  2. Oct 23, 2011 at 6:15 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    There are 2 adjustment screws on the back side of each headlight. The one that's up top and closer to the center of the truck adjusts the headlight left/right. There is another screw at the bottom, closer to the outside of the truck that adjusts the beam up/down. Use a long shank philips head screwdriver to make the adjustment. Pull the truck up to a vertical surface, mark where the beam is so you can tell which way you're going. If you park about 20' away from a wall, measure from the ground to the bulb on the truck then put a mark on the wall from the ground up the same distance. I make the 'hot spot' of the beam a few inches below this mark.
    Here's the technical way to do it:
    jasbk18, Norton and Texas2252 like this.
  3. Dec 21, 2011 at 9:24 PM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Holy s$%t i read that whole thing and it was hilarious. where in the world did you find that?
  4. Dec 22, 2011 at 5:41 AM
    Pugga
    Massachusetts
    It was posted on here a while back, I stole/borrowed it. It is pretty thorough... :rolleyes:
  5. Dec 22, 2011 at 5:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    :laughing:
    It's directly from the FSM
  6. Dec 22, 2011 at 6:05 AM
    Pugga
    Massachusetts
    The question is, do you think the Toyota techs actually follow all those steps?
  7. Dec 22, 2011 at 6:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    To a tee? Hell no.
  8. Jan 16, 2013 at 9:35 AM
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Ok so I decided to make an adj after getting flashed a few times then had a CHP officer tell me with a loadspeaker to turn off my High Beams in the snow. So I only see one screw which is going to need a nutdriver and would have to remove the washer resevoir and the battery to access it? Am I missing something here? Did they change things in the newer trucks? - seems like a PITA to make a simple adj.
  9. Jan 16, 2013 at 9:39 AM
    Pugga
    Massachusetts
    Open up the PDF I attached above. There are 2 screws, the one closest to the top (the one you see) adjusts the beam side to side. The other screw, further down and toward the outside of the vehicle adjusts the aim verticall (that's that one you want to adjust). You don't need a nut driver, they can be adjusted with a philips head screw driver from the top. No need to remove the battery or the windshield washer reservior, just need a long philips head screw driver.
    Norton likes this.
  10. Jan 16, 2013 at 10:18 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    hmmm...I need to adjust mine a little also...when I looked, I didn't see a Phillips head adjustment point...
    Guess Ill have to look further and report back...hopefully its not something that they changed on the 2012-2013...that would be stupid...
  11. Jan 16, 2013 at 10:21 AM
    Pugga
    Massachusetts
    I haven't seen the back of the 2012 or 2013 headlights but, assuming the adjustment is the same, there are 2 screws, both with hex heads. You feed the screw driver down perpenticular to the bolt, so the head of the screw driver catches the teeth on the inside edge of the adjustment bolt. So when you turn the screwdriver, the bolt turns with it. Look at page 4 on the PDF I posted, it shows how the screwdriver feeds in. On the 2005 to 2011 headlights, there are channels to guide the screwdriver in place.
  12. Jan 16, 2013 at 10:26 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    Yeah, I know where you are talking about, just didnt see that when i looked. Ill take a closer look after work today and post a pic to help others...
  13. Jan 16, 2013 at 11:15 AM
    skiomax
    skiomax Pro skier
    Ottawa, Ontario
    2013 Tacoma TDR Sport DC
    Extang cover Thule roof rack pop & Lock Short antena Weathertech floor liner TRD skid plate Leather Seat package
    My stealership told me there was not adjument posible on my 2013, not sure if the tech was just useless or they just didn't want to look in to it... I was not impress with being bruch off that quickley.
    anyone know if there any type of adjustment my hight beam are pointed so hight stock, i can't see anything in front for like 100 yards.
  14. Jan 16, 2013 at 3:37 PM
    HB Taco
    Curt
    BINGO! Now that its daylight and understand the part about the teeth I got it. Now after dark I'll make the adjustment! Thank You.
  15. Jan 16, 2013 at 4:56 PM
    Pugga
    Massachusetts
    :thumbsup:
  16. Mar 16, 2014 at 10:17 AM
    zonian
    zonian Well-Known Member
    Paul
    Knee Deep in the Hoopla.
    2012 TRD Sport 4X4 - Pyrite Mica
    Raptor 4" Black Oval Nerf Bars, Hard-Wired Uniden RD9XL Radar Detector, Anytime Fog Light Mod, 12V Power outlet in Bed, Tailgate Anti-theft Mod, Distinct Offroad lightbar, 2 Hella Micro FF Driving Lights, 2 Hella Micro FF Fog Lights, Rear Slider Window Opener
    I just did this adjustment today after replacing a broken headlight. I think these instructions are reversed:
    HINT:
    The headlight aim moves up when turning the
    aiming screw clockwise, and moves down when​
    turning the aiming screw counterclockwise.
    It should be:
    "HINT:
    screwdriver clockwise, and moves down when​
    turning the screwdriver counterclockwise."
  17. Mar 29, 2015 at 6:48 PM
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    I believe you have it wrong. If you have the screwdriver in the toothed washer thingy, you will turn the screwdriver CCW to make the toothed washer turn CW or adj.up and if you turn your screwdriver CW it will turn the toothed washer CCW or adj. down. :eek:
    Good luck and good job resurrecting an 2 1/2 year old thread.:rolleyes:
  18. Mar 29, 2015 at 8:11 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    no... they just let some air out of the front tires and call it good. :rolleyes:
    08TACO4BANGER, igno1tus and Skyway like this.
  19. Aug 8, 2016 at 7:52 PM
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    I have a 2015 and feel retarded that I can't find vertical adjustment
  20. Aug 8, 2016 at 8:04 PM
    Lthompson
    Lthompson Well-Known Member
    its possible they have white covers on the adjustment screws. Take em off. and then you can just use your fingers to spin the whole thing.. I recommend gloves... I wore blisters on my fingers. Still don't have mine right though.. My beams cross , Right headlight shines to the right side of the rode, and the left one shines on the right.. weird.. Ive backed em way off trying to get em right, but I'm still not there. And this is hard to tell when pulled up in front of something..
