how do u remove fog lights on gen 2
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KB24, Dec 14, 2011.
  1. Dec 14, 2011 at 10:47 AM
    KB24
    KB24 [OP] Well-Known Member
    miguel
    I.E
    2010 off road pre runner cherry red tail ligh
    Im going to install lamanex on my fogs but i cant figure out how to take off my fog lights can anyone help
  2. Dec 14, 2011 at 10:52 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    The adjuster screw on the bottom has 2 tabs on it that hold it in place, push those in while pushing the fog light housing from the rear (push the fog light toward the front of the truck). Once that releases, there are 2 alignment tabs, one on either side of the fog light housing about 1/2 way up that can sometimes get stuck on the holes in the bumper. Just wiggle it a little and they'll pop out.
    Here's a side view of the fog light, see the alignment screw on the bottom with the black plastic piece over it? That's what is holding them in place.
    Back view so you can see the tabs that stick out either side that can get caught and hold the light in place.
  3. Dec 14, 2011 at 10:54 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    This doesnt work????:confused:
  4. Dec 14, 2011 at 10:55 AM
    KB24
    miguel
    I.E
    Thnk bro
  5. Dec 14, 2011 at 10:55 AM
    KB24
    miguel
    I.E
    Hahah
  6. Dec 14, 2011 at 10:57 AM
    Pugga
    Massachusetts
    Ask jgwheeler, a BFH is his first choice for most repairs :p
  7. Dec 14, 2011 at 11:02 AM
    AsianAnts
    AnT
    what pugga wugga said :)
    but id think twice, look at all the rum he has in the background...:p
  8. Dec 14, 2011 at 11:04 AM
    Pugga
    Massachusetts
    The rum is only for the projector retrofit, not required for lamin-x install :cool:
  9. Dec 14, 2011 at 3:14 PM
    KB24
    miguel
    I.E
    Why the fuck is this do difficult they wont come off
  10. Dec 14, 2011 at 3:16 PM
    AsianAnts
    AnT
    please see post #3......
    JK JK JK... you have your bumpers off?? try using a small flat head screw driver to help you press those little clips.
  11. Dec 14, 2011 at 3:20 PM
    Pugga
    Massachusetts
    See the attachment. Press the tabs (see the arrows) and then that should release the adjustment screw from the bumper. Then pop the sides out of their holders (see the clouded area and the nubs sticking out). These nubs seat into holes on the bumper and can hold the fog light in place. Don't forget to unplug the bulbs :D
  12. Dec 14, 2011 at 3:21 PM
    Pugga
    Massachusetts
  13. Dec 14, 2011 at 3:29 PM
    KB24
    miguel
    I.E
    Im trying to push those tabs in but its a no go
  14. Dec 14, 2011 at 3:31 PM
    Pugga
    Massachusetts
    Push in the tabs and push the alignment screw portion out of the hole in the bumper, then turn your attention to the side tabs. Once the bottom alignment screw is not held into the bumper, twist the light so it pops out. Keep them plugged in at first, they tend to release with a little pressure, that way you won't send the light flying.
  15. Dec 14, 2011 at 3:41 PM
    KB24
    miguel
    I.E
    Do i have to tKe off the bumper
  16. Dec 14, 2011 at 3:45 PM
    Pugga
    Massachusetts
    No, I got mine off in about 30 seconds just by laying on my back under the front of the truck. You absolutely do not need to remove the bumper.
  17. Dec 14, 2011 at 3:53 PM
    KB24
    miguel
    I.E
    I am pushing those tabs still a no go.....
  18. Dec 14, 2011 at 4:01 PM
    Pugga
    Massachusetts
    I don't really know what to tell ya man... All I did was push the tabs in, pop that part out of the hole in the bumper, then push from the back of the fog light and the whole light popped out. Those tabs are the only things really holding the light in place.
  19. Dec 14, 2011 at 4:04 PM
    KB24
    miguel
    I.E
    Nvmd i got them out thnks man!!!! Now i wanna retro fit lol lamenex for now
  20. Dec 14, 2011 at 4:07 PM
    Pugga
    Massachusetts
