How do y’all “exercise” your 4 low?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Avotaco, Sep 2, 2023.
  1. Sep 3, 2023 at 9:22 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    The actuator has limit switches that won't be tested and motor end limits if 4LO isn't engaged. You need to do both...10 miles in the manual is just bullshit. As long as you swap between 2HI, 4HI, and 4LO several times a year you're good.
  2. Sep 3, 2023 at 11:20 PM
    TacoTuesday1
    FL
    taco can be converted to manual tcase.
    take a new car 80 computers, dealer computer lets you check history on the vehicle coming in for work. Been there 30 times. 40 bulletins. Numerous applicable. Numerous solution pending no current fix.
    And more complex emissions system (even gasoline) that is more failure-prone.
    Navigation system that runs out of subscription or gets support discontinued.
    20yo same car with a handful of the computers doing 200k on oil changes.
    With said computers simple enough for basics tasks that they’re not getting bugs and needing constant out of pocket updates for $220+/hr that only dealer can do with their server access.
    No applicable TSB’s.
    Bivouac likes this.
  3. Sep 4, 2023 at 1:20 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    not true the Tacoma 4wd computer doesn’t throw codes
    fatfurious2, GilbertOz and Bivouac like this.
  4. Mar 23, 2024 at 6:31 PM
    SmartyMcFly
    SmartyMcFly 88 MPH
    2023 TRD Off Road 4x4 Ice Cap
    Do I need to “exercise” the rear locker? I tried it this morning and it stayed flashing on the dash. Besides putting it in 4lo 1st, is there a trick to get it to engage?
  5. Mar 23, 2024 at 6:42 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yes you do or it can get stuck just like the 4wd actuators. Mine did when I didn't use it for awhile but a little tapping on it got it going again.
    You can try weaving side to side while trying to engage it.
    If that doesn't work get you a helper, put it 4L, get a small hammer and crawl under the truck, get your helper to operate the locker while you tap on the motor lightly.
  6. Mar 23, 2024 at 6:58 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    FWIW: I exercise 4L about twice a month in my driveway. I engage it back and forth from 4H a few times, and move it forward about 10 feet on the last one. When I'm out on Forest Service Roads or Jeep trails to fishing spots etc out in the woods, I don't trust it to shift back out of 4L, so I never do it unless I'm on sketchy downhill slopes to control speed. Each test seems to sound better and go a little smoother and less noise than the first, so it seems to make a difference. I engage 4H anytime I'm on wet or snowy streets.... maybe once per month for a few miles.
    If it hasn't rained or snowed for a while, I just do it parked in the driveway a few times while waiting for it to warm-up for a minute or so.
  7. Mar 24, 2024 at 12:27 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I'm fortunate enough I live near plenty of dirt and gravel roads....the dirt roads become rather slick in the mud and I just use them then.
    jackn7 and Superdave1.0 like this.
  8. Mar 24, 2024 at 6:36 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I’ve got a big grassy field behind my
    House. At least once a month I go do figure 8s in low and high.
    GT2000 likes this.
  9. Mar 24, 2024 at 6:42 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I know this is an old post in a revived thread but…have you actually looked at the manual you posted? It has no table of contents, no index, and none of the terms I would think to search even come up. For my 2015 vehicle I recall a recommended monthly usage of the 4 hi but don’t recall anything about 4 lo.
    Anyway if I was the OP I’d much prefer a one minute response from someone who knew the answer to the question to thirty minutes of rifling through a poorly organized owner’s manual.
  10. Mar 26, 2024 at 4:44 PM
    riverrat958
    riverrat958 Well-Known Member
    keith
    upstate ny
    2015 base crew cab tacoma
    camera source backup, camera seat covers,intermittent wiper arm
    up state ny here- I mostly use 4 wheel drive in winter. but during the year I "exercise" it at least monthly. 4 hi and then 4 low up and down driveway a few times( driveways about 200ft)
  11. Oct 21, 2024 at 10:41 AM
    GT2000
    GT2000 Well-Known Member
    Middle TN USA
    2009 DCSB V6 TRD Sport 4x4
    Glad I ran across this thread...and that I'm not within an arm's reach of someone here popping me upside the head. When the truck is in L4, should you always stay in Low (L) gear OR...is it okay to drive in L then shift to 2, drive a ways (few hundred yards, maybe), then shift to 3 (same), then shift to 4 (same). I never have driven L4 in OverDrive (D). I'll admit I've never run in Reverse in L4, yet, but sounds like I should. I do drive regularly H2 at times on appropriate terrain through L, 2, 3, 4, & D. When (or if) it ever snows/ice here in middle TN, man, I put it in H4 and my truck just doesn't break traction and I try (not stupidly, of course) and I'm driving carefully. Anything I'm missing out on or "never do that dude", etc.? Thanks in advance!
