How do yall get oil into the transmission?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Country101, May 16, 2012.
  1. May 16, 2012 at 7:35 AM
    Country101
    Country101 [OP] Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    ^ what that says. I dont see how you are supposed to be able to fill it. There is no way to get a bottle in there. Any ideas?
    And while we are on the subject, why do they think the front dif needs to be removed with allen wrenches? Why couldnt they use the same plugs as on the rest of the truck?
  2. May 16, 2012 at 7:51 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's, Pioner AVH-2300NEX w/backup camera, SCT X4 Tuner.
  3. May 16, 2012 at 7:54 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
  4. May 16, 2012 at 7:59 AM
    Maticuno
    03 F250 CCSB
    I use the giant syringe now. You have to crawl out from under the truck and back a few times to reload it, but that is much easier than laying under there squeezing the pump for an hour. If you're going to use the syringe type, don't suction the new fluid into it, just unscrew the top and fill it up.
  5. May 16, 2012 at 8:39 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    I ran a hose from the input up through the engine bay, attached it to a funnel and hung the funnel from the hood latch (hood open obviously). Then just pour away. Worked pretty good :thumbsup:
  6. May 16, 2012 at 8:46 AM
    Country101
    NW Arkansas
    Pugga, that's a pretty good idea there. I like that better than the syringe or a pump. Now I just have to find some hose.
    Thanks folks.
  7. May 16, 2012 at 9:13 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Just make sure you spray those bolts up pretty good and make sure the torx wrench is right size. You dont want to strip those out. My front diff at 40k looked new, my back was black as hell. I would change though.
  8. May 16, 2012 at 9:52 AM
    Country101
    NW Arkansas
    My rear and trnasfer case looked pretty good for 90k. Rear diff might have looked a little worse for wear, but not like I was expecting.
