How do you camp with a 5ft shortbed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Nov 10, 2019.
  1. Nov 11, 2019 at 3:49 PM
    #81
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I think I paid $110 for my 2 person Eureka back in 2011. Its been camped in quite a lot, but its also nice that it takes up almost no room when I'm not using it, I can just air it out and toss it in the back of the closet. And when it finally does give up the ghost, its cheap to replace. It also doesn't require that I bring my truck - I can take it on a motorcycle. Or put it in my backpack. I just can't wrap my head around the whole rtt tent thing, at least not for my use cases.
    Like you said its also nice for not breaking camp - or for marking your spot. Pull in, throw it down in the spot you want, then hit the grocery store or whatever. Lots of strategic flexibility.
    nonohmic[QUOTED] likes this.
  2. Nov 11, 2019 at 3:55 PM
    #82
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    RTTs are a lot more comfortable when you’re camping in the parking lot at Walmart. :D
  3. Nov 11, 2019 at 3:56 PM
    #83
    0xDEADBEEF
    I make it a point not to camp somewhere that I can camp at home :laughing:
    Malvolio likes this.
  4. Nov 11, 2019 at 3:58 PM
    #84
    Halligan
    Halligan Old School
    Cam
    BC Canada
    2015 DCSB Gearjammer
    OME 887s, OME Dakar Heavys, 265/70/17's, Truetrac, 6sp manual
    I tow a little military trailer that can handle anything the truck can off-road wise. Works well. 58940423105__65D99170-7AD3-4CE8-A114-9B89E236B973.jpg
  5. Nov 11, 2019 at 4:06 PM
    #85
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I got a regular cab with a 6' bed. The wheelbase is shorter than a DCSB or an Access Cab long bed. Problem solved.
    DavesTaco68 and jowybyo like this.
  6. Nov 11, 2019 at 4:06 PM
    #86
    WhiteTruckMafia
    WhiteTruckMafia Well-Known Member
    TN
    19 TRD PRO
    Sleeps in a wonderful thing....... A tent. If it’s insanely bad out I do another wonderful thing............... I lay my seat back and lock my doors.
  7. Nov 11, 2019 at 5:16 PM
    #87
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Had that one for 7 years now and yes it is basically free standing with spring poles and you can use it as a tent alone or hooked to the truck and you can unhook the straps that hold it to the truck and close the side up to take off for the day. Similar tents on autoanything.com still. Sure you can find these lots of places online. I used a foam pipe weather insulator to put on the shell rear window so it would not rip the tent when up and it just pushed on so easy on/off. My shell struts are pretty strong. Wish someone made a support rod to lock that window open at 90 degrees but never found on or thought of how to make one to easily work (bed to window) so in heavy rain or winds it would be secure/not vibrate or shake at all.
  8. Nov 11, 2019 at 5:22 PM
    #88
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Pitch a tent? Seriously takes 5 minutes, costs $150 for a premium large, is mobile and you can make an ice/beer/hookers (according to “a friend”) Run without breaking camp.
    WhiteTruckMafia likes this.
  9. Nov 11, 2019 at 5:31 PM
    #89
    jowybyo
    Joe
    Baltimore, MD
    It’s funny that people get so defensive about their choice of camping structure. They all have pros and cons. Certain styles of camping require different setups. A tent works great if you are backpacking or even hanging out at the local KOA for the week. If you are moving camp everyday, it sucks pulling out a bunch of stuff to setup a shelter. Other setups can be helpful and worthwhile. That said, I have 3 ground tents, a RTT and I occasionally sleep in the 5’ bed of my truck. They all work equally well depending of what my trip involves.
  10. Nov 11, 2019 at 5:45 PM
    #90
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Want to make me one?
    Tacotsubo[QUOTED] likes this.
  11. Nov 11, 2019 at 5:48 PM
    #91
    uploadadventure
    Dixon, Mo
    Oh I know how much work it is. That’s why I asked if you want to make me one lol
  12. Nov 11, 2019 at 5:52 PM
    #92
    JasonArizona
    JasonArizona Well-Known Member
    Tucson
    2014 TuRD
    You beat me to it. This works wonders and only around $250 for the oversized version. I've had mine for three years and it's seen plenty of use. Off the ground and ideal for car camping. I have a real (light) tent for backpacking.
    http://kamprite.com/product-category/tents/tent-cots/
    Brownie_Man[QUOTED] likes this.
  13. Nov 11, 2019 at 6:12 PM
    #93
    mandog
    mandog Lesser-Known Member
    Race City, USA
    2017 4WD Off-Road Quicksand Overland
    I appreciate seeing different modular setups. Looks good! :thumbsup:
    What kind of cooler is that, and how does it hold up on multi-day runs?
  14. Nov 11, 2019 at 6:23 PM
    #94
    jerBEAR
    jerBEAR Well-Known Member
    I sleep on top of it.
  15. Nov 11, 2019 at 6:29 PM
    #95
    levie125
    levie125 Well-Known Member
    2019 DCLB TRD
    Dude there should be a whole thread for how you transported that flagpole to the beach!
  16. Nov 11, 2019 at 6:33 PM
    #96
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    I'm a pretty good organizer. :rofl:
    The flagpoles are under the tiki torches.
  17. Nov 11, 2019 at 6:35 PM
    #97
    levie125
    2019 DCLB TRD
    Haha, thats awesome. That sums up how the back of my truck looks when I go camping, thus no sleeping in the back for me.
  18. Nov 11, 2019 at 6:37 PM
    #98
    ResearchMonkee
    Derrick
    KCMO
    Whew, yeah. It's a struggle.
    I used 1 big tote, 2 littles, my 65 quart RTIC, and some misc stuff. Had passenger, so had additional cooler and various other stuff.
    Can't wait for an RTT.
    Sure is!
  19. Nov 11, 2019 at 6:40 PM
    #99
    levie125
    2019 DCLB TRD
    I'm glad you planted that KC flag in Cowboy country!
  20. Nov 11, 2019 at 6:41 PM
    #100
    ResearchMonkee
    Derrick
    KCMO
    My friends and I were on a time crunch and left the Friday before the Saturday of the meet up. I was so disappointed.
    I did meet a few folks in San Antonio though.
    LostHusker and Tacotsubo[QUOTED] like this.
