How do you carry propane tanks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sand Dog, Jan 13, 2019.
  1. Apr 22, 2023 at 9:01 AM
    #41
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I use a ratchet strap and strap it to the side of the bed.
    Recently bought a 5 pounder, so much nicer than lugging a 20 pounder around.
    mic_sierra and Martin64 like this.
  2. Apr 22, 2023 at 9:08 AM
    #42
    TacoTuesday1
    FL
    So,
    I found a couple places that do, or likely will refill
    Tractor Supply
    Flying J
    etc.
    Tractor Supply told me yes, but that it needs to have an adapter on the 5lb, that makes it act like a 20lb
    which suggests their machine is setup to fill 20lb tanks normally,
    or a 5lb with adapter on it "pretending" to be a 20lb
    If I can figure out what that adapter even is
    Told me they specifically don't do swaps, only refills
    and maybe return this milk crate
    was gonna pick up a #20 but I already know it's huge
    I guess there's only one way to find out what the best tank is (5,10,11,20) and how long it lasts; to get it and try it
    possibly sell later if changing
    Or, hopefully, just trade that, as big store #20 re fillers supposdly accept *any* tank from you
    Martin64 likes this.
  3. Apr 22, 2023 at 9:11 AM
    #43
    Martin64
    Martin64 Well-Known Member
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    If I find one cheap and local I'd like to have one. That would be pretty handy to have. But between the rv and off road folks they are very popular down here.
    Junkhead[QUOTED] likes this.
  4. Apr 22, 2023 at 9:14 AM
    #44
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Yeah, I know the place, I do a lot of prospecting off Gold Crown Road. Thanks for the link to the tank mount- appreciate it!
    bonuscup[QUOTED] likes this.
  5. Apr 22, 2023 at 9:24 AM
    #45
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    Your performance will vary. I have 5, 7 1/2 and 10 gallon tanks (20, 30 and 40 lb) for the different propane appliances I have but I wouldn't think you'd need anything bigger than a 20lb if you are just camping. I can get about 5 days out of a 20lb running about 5-6 hours/day on a 30,000 btu burner about 1/4-1/3 capacity (about medium low). That may get you some ball park numbers. I think a 5lb is about a gallon or so.
  6. Apr 22, 2023 at 9:30 AM
    #46
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    these are awesome for the 5lb tanks :thumbsup:
    Bunch more tank mounting options in the thread over here :D
  7. Apr 22, 2023 at 9:30 AM
    #47
    84-4runner
    84-4runner Well-Known Member
    frank
    Northern Arizona
    2019 tacoma offroad
    intake mods, firestone airbags, campershell, backup lights,
    the fitting is the same on the 5 lb and 20 lb and all that I know of
    they just may be confused about what you want. The only weird one is the same one pound kind.
    someone mentioned an adaptor for a little buddy, I got one with hose from tractor supply when they
    had a sale. there was a great tutorial in "OVERLAND JOURNAL" and shows what you need in different
    courties and how to refill the little 1 pound ones. I will try to find the issues and let you know.
    Propane Tank Mount - Etsy
  8. Apr 22, 2023 at 9:32 AM
    #48
    TacoTuesday1
    FL
    11 sounds good
    I believe it's the same width as 5 but taller
    just can't find it anywhere
    looked online at Lowe's, TSC, Ace, THD, WM, etc.
    Martin64[QUOTED] likes this.
  9. Apr 22, 2023 at 9:40 AM
    #49
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    I've seen those advertised but never seen on in person and I think you're right about taller.
    Not to get totally away from conventional thinking but a buddy of mine has brought the idea of using a motorhome tank for different ideas. They have different sizes, mount or carried horizontally and may be handy for different ideas...just throwing that out there.
    edit: he also uses forklift tanks. Those can be verticle or horizontal but they are a little heavier.
  10. Apr 22, 2023 at 9:42 AM
    #50
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    I only buy propane and propane accessories from Strickland Propane. That Assistant Manager Hank Hill knows his gas I tell you hwhat.
  11. Apr 22, 2023 at 11:04 AM
    #51
    wayne0
    wayne0 Well-Known Member
    I use a 10lb. tank for the grill on my boat. Bought it in the jungle.
  12. Apr 22, 2023 at 11:15 AM
    #52
    OnHartung'sRoad
    Hey, just a suggestion- I’ve seen a lot of photos of tanks here that don’t have covers over the gas valve outlet. You can usually get a free plastic one at a propane refill station, just ask. They usually have a bunch of those laying around.
    Keeping the dirt out might help prevent your jets from getting clogged up on your stove and on other equipment. You won’t have to blow it out or by wasting propane.
  13. Apr 22, 2023 at 11:19 AM
    #53
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    My trailer came with something similar to this mount (only one strap to secure the tank vs. two pictured). No idea what brand it is since it came w/ the trailer. I like the turn buckles so you can adjust the tension and I drilled holes through the latch and use a master lock to keep the riff raff from being tempted to take it when I overnight in truck stops and RV parks.
  14. Apr 23, 2023 at 9:52 AM
    #54
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Thanks!
    RyanDCLB[QUOTED] likes this.
  15. Apr 23, 2023 at 10:04 AM
    #55
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yeah it cost me 60$…
  16. Apr 23, 2023 at 10:16 AM
    #56
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    I've found the best place to carry our 30gal LP fire pit tank is to fold down the rear pass seat, and use a ratchet strap to secure it from the rear most seat hook to the side hook.
    It's kept it completely stable and free of any shifting, even over the roughest of terrain on every trip we have taken.
    Would work similarly for a 20gal although I haven't tried that.
    I know lots of peeps are against carrying them inside but I've found it's not an issue as long as you keep certain safety measures in place.
  17. Apr 23, 2023 at 10:22 AM
    #57
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I use a milk crate for 20lb tanks too. I have a few 1lb tanks and a refill adapter for them if I need portability. They work great for torches, lantern, or a quick tailgate stove lunch. When they get old, the schrader valves in them start to leak, however.
  18. Apr 23, 2023 at 4:45 PM
    #58
    Martin64
    Martin
    Yuma, Az
    1998 Tacoma TRD 4x4
    Stock
    I wouldn't do that down here in summer. I wouldn't want that over pressure valve opening while I was driving. I have done it in my Jeep with the rear hatch open but not for very long.
    Out2gtcha[QUOTED] likes this.
  19. Apr 23, 2023 at 5:08 PM
    #59
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    +1….use a ratchet strap around them for insurance if I’m only carrying one or two.
    That thing is the best $25 I’ve spent, use it for propane, gas cans, chlorine cans for the pool, big packs of toilet paper from Costco, whatever.
  20. Apr 23, 2023 at 6:24 PM
    #60
    Out2gtcha
    Brian
    Omaha, NE
    Yep, for even remotely hot weather I actually agree. Really the only time we carry it is when we are taking our LP fire pit with us because it's getting in the 40s or below.
