How do you check the ATF in the 5 speed automatic?
Discussion in 'Technical Chat' started by Spillwaybob, May 23, 2008.
  1. May 23, 2008 at 6:17 AM
    Spillwaybob
    Spillwaybob [OP] Member
    Metairie, LA
    2009 Access cab V-6 4X4 SR5 pkg.
    My 2008 Taco V-6 5 speed auto does not have the conventional dipstick for the trans. How do you check and/or add oil to the transmission? Thanks for your help.
    Spillwaybob
  2. May 23, 2008 at 6:23 AM
    missileman125fw
    missileman125fw Well-Known Member
    I believe its one of those deals where you have to take it to the dealer.
  3. May 23, 2008 at 7:28 AM
    Spillwaybob
    Metairie, LA
    On the bottom of the transmission pan there is a plug marked "check" and probably when you remove this, the oil will run out until it gets the proper level but where do you put oil in?
    Spillwaybob
  4. May 23, 2008 at 7:33 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's somewhat complicated - from what I've read.
    It's VERY important you get the tranny up to proper operating temperatures before you check it.
    If you click here:
    http://www.markass.com/toyotanation/
    Click on "2005 tacoma a750e" (2nd one)
    You'll be prompted with an OPEN or SAVE box.....
    Scroll down to where it says "aft inspection 1gr fe.pdf"
    It's probably better off to take it to the dealer and have them check it. Personally, I wouldn't mess with it while it's still under warrantee.
  5. May 23, 2008 at 12:44 PM
    Spillwaybob
    Metairie, LA
    Thanks, Janster for the information. It's hard to understand why Toyota made this so complicated. My truck had the radiator replaced due to an accident and the Toyota Body Shop didn't top up the ATF and told me to take it to the dealer which I did. It cost the body shop $125 to perform this proceedure and top up the oil. Glad I didn't have to pay for it. Thanks again for the information.
    Spillwaybob
  6. May 30, 2008 at 11:21 PM
    carlos chavez
    carlos chavez New Member
    05 PreRunner SR5
    3" Revteck lift All Pro upper control arm 17"Mickey Thompson's wheels 33" BFG KM2
    I have a 2005 prerunner and I'had the tranni changed after 41000 mls on it, cause it was shifting roughly on 1st and 2nd gear the dealer changed it no questions asked, so I found out talking to the technician at Toyota that the transmision has to be level there is plug w/the letters WS fill it up until it spills over, almost the same as changing the oil on your differential, be careful to make sure there is oil in it or else
  7. May 31, 2008 at 8:04 AM
    Janster
    Jandy
    Lancaster, PA
    It's very very important that the tranny is 'up to temp'........you can't just crack open the fill hole and top it off.
  8. Jun 1, 2008 at 8:34 AM
    Spillwaybob
    Metairie, LA
    On transmissions with dipsticks, there is a HOT level and a COLD level so if you get the Taco 5-speed up to normal operating temperature, I would think that adding oil until it runs out of the level plug would be pretty close to correct. It's hard to believe that the exact level is that critical and Toyota's proceedure for checking sounds like a lot of hype and an attempt to keep the do-it-youself guy from doing what should be a simple job. My two cents.
    Spillwaybob
  9. Jun 1, 2008 at 8:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I agree with you. I have been searching for a few weeks now on how to check/ service these new trannys, and everything I find seems to point me back to the dealership. :confused:
  10. Jun 8, 2008 at 12:38 AM
    ebnash
    ebnash Active Member
    San Jose, CA
    06 Access Cab 4X4 Auto
    I callled a few different dealerships and got the following information:
    If you tow with your truck, have it serviced every 30,000-45,000 miles.
    Otherwise, they consider the ATF to be lifetime and tranny does not need service. However, all of the dealerships suggested I bring the vehicle in at 100,000 miles to have it flushed and replaced.
    There is no documented service interval unless you tow???
  11. Jun 8, 2008 at 4:15 AM
    danusa
    danusa Well-Known Member
    I bought the Taco because I grew weary of maintance.
    Let the dealer worry. He sees it every 5.000.
