How do you clear a trac off and check engine light after installing a new camshaft sensor?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fabfourtacoma, Dec 24, 2019.
  1. Dec 26, 2019 at 5:00 PM
    Fabfourtacoma
    Fabfourtacoma [OP] Well-Known Member
    2016 tacoma trd off road
    3inch revtech lift 33inch durtrac w 2 inch offset fabfour front bumper 4 rigid 4x4 and a 20 inch rigid led bar
    It comes back
  2. Dec 26, 2019 at 5:01 PM
    Fabfourtacoma
    The dealership gave me the wrong sensor to start with. The motor wouldn't even fire
  3. Dec 26, 2019 at 5:07 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Your code is for a cam sensor...
    Did you replace the crank sensor?
    CPS is cam sensor.
    CKP is crank sensor.
    Everyone uses CPS to describe the crank sensor...
    Skydvrr likes this.
  4. Dec 26, 2019 at 5:08 PM
    Fabfourtacoma
    Cam sensor
  5. Dec 26, 2019 at 5:09 PM
    Fabfourtacoma
    P0348 was the code
  6. Dec 26, 2019 at 5:15 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    is there 2 cam sensors on your vehicle?
  7. Dec 26, 2019 at 5:17 PM
    wilcam47
    Will
    Bourbon state
  8. Dec 26, 2019 at 5:26 PM
    Fabfourtacoma
    wilcam47 likes this.
  9. Dec 26, 2019 at 5:32 PM
    wilcam47
    Will
    Bourbon state
    :notsure: doesnt v6 have 2 cams? so 2 sensors? I dunno just thinking outloud..
  10. Dec 26, 2019 at 6:22 PM
    Fabfourtacoma
    Toyota calls camshaft position sensor and crank position sensor the Sam thing
  11. Dec 26, 2019 at 9:04 PM
    Fabfourtacoma
    where is the other camshaft sensor located??? i found the passenger side one.
  12. Dec 27, 2019 at 4:00 AM
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    The V6 has an intake and exhaust camshaft position sensor. However, the 0348 code is for the #2 bank VVT sensor. The only way that code would display in relation to the camshaft position sensor is if the Camshaft Position Sensor "A" was shorted on the battery side or left open. I.E. It sounds like either you have a bad sensor or a break in wiring.
    Here are the Camshaft Position Sensors:
    Two totally different initialisms for two totally different sensors: Camshaft Position Sensor (CPS) and Crankshaft Position Sensor (CKP)
    Skydvrr likes this.
  13. Dec 27, 2019 at 4:51 AM
    splitbolt
    NW Arkansas
    Skydvrr likes this.
  14. Dec 27, 2019 at 5:16 AM
    Fabfourtacoma
    Yep so when I told the dealership I need a camshaft position sensor the idiots sold me a crankshaft sensor smh I think that is the problem
  15. Dec 27, 2019 at 5:17 AM
    #35
    TuRDLYFE
    2020 AG TRD Pro 6MT
    That's the correct part number for his application. These magnetic sensors are common equipment and in this case the same part number is also used as a crankshaft position sensor on some Camrys and Highlanders. I'd need the exact date of manufacture and engine code to tell you for sure.
  16. Dec 27, 2019 at 5:19 AM
    #36
    TuRDLYFE
    2020 AG TRD Pro 6MT
    Look into part number 90919-T5005. I think that was the original part number for your application. If not that, then look at 90919-05061.
  17. Dec 27, 2019 at 5:29 AM
    #37
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I'd be looking for a break in the wire. I doubt a cam sensor is bad already, but maybe. Can u ohm out a hall effect sensor?
  18. Dec 27, 2019 at 5:29 AM
    #38
    Fabfourtacoma
    I put my old sensor back in. Whick cam sensor is bank 2.
  19. Dec 27, 2019 at 5:31 AM
    #39
    Fabfourtacoma
    Can you send me the link
  20. Dec 27, 2019 at 5:34 AM
    #40
    Skydvrr
    Nick
    YMH
    Black '17 OR
    A link of what? Idk if it even possible
