How do you drive 5 speed manual?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gyprat, Feb 13, 2011.
  1. Feb 20, 2011 at 11:33 AM
    #121
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    sorry, no hard feelings:eek:
  2. Feb 20, 2011 at 5:23 PM
    #122
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    All the people with the v6 and 6 speed really need to to stop posting in this thread. You have a different tranny and a more powerful engine...your opinion on this matter is useless.
  3. Feb 20, 2011 at 5:27 PM
    #123
    yotataco94
    yotataco94 Active Member
    Brandon
    Cumberland,RI
    2001 tacoma 2.7 5spd sr5
    31/10.5/15
    Thts exactly what im thinking. theres no point in putting it in first if your moving
  4. Feb 20, 2011 at 5:48 PM
    #124
    ruskastud
    ruskastud Well-Known Member
    Lenexa, KS
    '10 Tacoma Double Cab 4x4 TRD Off-Road
    AVS Hood Shield & In Channel Ventvisors, Console Vault, Disable Seat Belt Chime, WeatherTech DigiFit Floor Liners, Lighted 4x4 Switch, Ultra-Gauge, Rear Spring TSB
    I'm no expert, but I don't think ANY transmission wants to be put in 1st if you're going more than like 2miles/hr. WHY!!!???
  5. Feb 20, 2011 at 6:56 PM
    #125
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    That's not what we're talking about. The problem deals with the gearing of the 5 speed. There are times when you're approaching a light or traffic going anywhere from 5 to 10 MPH, and you can't go into first, but second gear lugs badly because the engine doesn't produce enough torque. If the engine made more power, or the gearing was more evenly spaced, it would be a non-issue. The V6 has enough power to go straight into 2nd without lugging...hence why they don't understand what were talking about.
  6. Feb 20, 2011 at 7:13 PM
    #126
    RobZ71LM7
    RobZ71LM7 Member
    Mount Washington, KY
    09 Tacoma Reg Cab, 2.7L 5-speed
    Ditto. There a lot of people in this thread that don't know what they're talking about since they haven't driven a 4cyl, 5-speed Tacoma. The 5-speeds have a huge gear ratio change between 1st and 2nd coupled with a, in my opinion, two high rear end gear ratio which make things interesting. When below 11mph (aka parking lot speeds) 2nd will lug the engine really bad. It's just annoying how they geared these trucks. My other 4cyl and V8 cars with sticks are not like this since they're geared differently.
  7. Feb 20, 2011 at 7:14 PM
    #127
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    The 6-speed will lug if you try to go 5-10mph in 2nd gear.
    But as mentioned earlier in this thread, if you bring the RPMs up, it will go into 1st. I'm assuming the 5-speed will, too.
  8. Feb 20, 2011 at 7:17 PM
    #128
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    It will go into 1st if you rev match. But it would be nice if you could just use second. It's not a big deal. I was bothered by it at first, but I don't even think about it anymore.
    And on a side note, I thought the V6 made more than enough torque for people to start in 2nd gear fairly easily? I guess I was misinformed on that one.
  9. Feb 20, 2011 at 8:49 PM
    #129
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    So to clear things up (yea right) toyota says not to use 2nd to start..non issue we all get that. The point of shifting into first from 2nd while moving ... IT IS LEGIT.... not only is it there to get the vehicle moving , but like any other truck/car , you should downshift into it as needed ,such as in the neighborhood , mine is posted at 5 mph , so is my work place so....
    henceforth and further more anyone argueing,saying you are not supposed to shift into 1st, from 2nd on a 5 spd tacoma manual , to continue on at around 2-5 mph.....is an idiot who needs to gain driving experience. Personally,I try to avoid the downshift,but there is no reasonable explanation as to why it is finiky. Only that its a bad design an otherwise good truck.
  10. Feb 20, 2011 at 9:06 PM
    #130
    ibengineer
    ibengineer Well-Known Member
    California
    00 Tacoma TRD 4x4
    Dirt Logic 2.5" Coilovers, Camburg UCA's, Icon 3 Leaf add-a-pack, billy 5100's in the rear, Custom front Plate bumper, XRC 8500 lb winch, lots of little mods
    dont force it into 1st if you are going too fast, dont bog it in 2nd if you are going too slow. its simple: use the speed/gear shift guidelines in your owners manual and you will be fine.
    ~157k miles and I have never changed the clutch or needed to....just sayin
  11. Feb 20, 2011 at 9:23 PM
    #131
    Tacoyota
    08 4wd
    once again that is easy answer that is not applicable. Here is why ..
    1) you dont have the 2.7L 5 spd and may have never drove it .Anyone who isnt driving the 2.7l 5 spd and never have,please save the arm-chair answers, they wont help.
    2) slow enough to finally get into 1st with this transmission means you are lugging it in 2nd , no room to interpret it ..... no-one wants to force it , noone is "going too fast". Even at 2 mph it will resist many times.
    ps the guideline in the book says not to down shift at a speed faster than the recomended maximum upshift. Since the max upshift for a 4wd 5 spd is 30 mph , that point doesnt even apply since i dont think 99% +/_ of tacoma owners would even try to downshift at 30 mph. Yes im sure some have but thats not the point.
  12. Feb 20, 2011 at 10:09 PM
    #132
    ninorth
    ninorth T-REX
    Nick
    Yucca Valley, CA
    06 Access cab 4x4 off-road
    People that have a 6 cylinder now sometimes have had or also have a 4 cylinder. Sometimes you have to go into first. Driving in snow and or ice I have had to put my 4 and 6 in to first. Dry surfaces going up a really steep hill making sharp turns you have to go into first.
  13. Feb 21, 2011 at 5:42 AM
    #133
    Tinfish
    Tinfish Active Member
    2013 Reg Cab 4x4 5spd
    Again, they aren't all like that. Mine shifts into first while moving just fine, so there's no need to lug in second. I wish the axle gearing was a bit lower (or that the transmission was geared lower, I guess), but that's a different issue. And like I said before, the other 2005+ five speeds I have driven were fine, too. Definitely clunky truck transmissions, not smooth like a car. But adequate and easy to drive.
  14. Feb 21, 2011 at 9:27 AM
    #134
    bigcoffinhunter
    bigcoffinhunter Well-Known Member
    There is a definite 'dead zone' with the 2.7 x 5speed. Too fast to shift into first, lugs like hell in 2nd. The gearing on them sucks, the 1st gens were geared far better. My solution was to trade for a 6cyl auto (better mpg and no throwout bearing issues there).
  15. Feb 21, 2011 at 9:36 AM
    #135
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    You have to double clutch to get it into first. In fact, you should be double clutching whenever down sifting. It will make things a lot easier, smoother, and is less wear and tear on the tranny.
    But I will agree that the 2nd gen 6 sp sucks. I thought the first gear was a bit too big (def not a towing gear) and the clutch to be very hard to read. I only test drove one so didnt have much time to get used to it, but i didnt like it at all (it was a V6 model).
  16. Feb 21, 2011 at 11:24 AM
    #136
    tmacbigbass
    tmacbigbass Member
    09 Prerunner
    I have a 09 that does the same thing your does. When I am stopped I let the clutch out to make the gears spin then push the clutch back in and then it falls into first. You can do the same with reverse.
  17. Feb 21, 2011 at 12:35 PM
    #137
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Happens on other cars with other stickshifts too, eh?
    I humbly invite you to consider the possibility that despite your class B drivers license and millions of miles driving stick, there's just maybe, possibly, something about driving stick you are not doing right.
    My 2011 5 speed 2.7 4 banger 4x4, driven by me, does not have any problem at all going into first. As I mentioned before, I can downshift from 2nd to 1st at 25mph if I want to, and I've done it.
    Either
    1. I'm a liar
    2. There's something different about your truck (and those other stickshifts you've driven) than my truck (and all the other stickshifts I've driven)
    3. There's something about your driving that's different from my driving
    Take your pick.
  18. Feb 21, 2011 at 1:22 PM
    #138
    Yoytoda
    Roland
    completely stock
    I meant that other Toyota 5speeds I've driven have the same issue. Not all vehicles I've driven
    My civics, gto, other trucks have all be fine shifting into first. Yea if you are doing 20 you need to double clutch/rev match. But MY Tacoma is tough to shift and I've driven other tacomas that are tough. Ninorth's 6speed is so smooth in comparison.
  19. Feb 21, 2011 at 3:57 PM
    #139
    Gyprat
    Gyprat [OP] Active Member
    2010 4 cyl, SR5, Manual
    Changing to Redline MT-90 helped some but it was real clunky when shifting from 1 to 2 and 2nd to 3rd. Better than factory oil but not as smooth as it should be. I did some research and found that many people don't recomment using synthetic fluids in manual transmission. So out of desperation I bought the cheapest hypoid oil that Autozone had - Coastal
    80W-90 API Service GL3, GL4, GL5. Coastal oil made a big difference. Now it shifts much much smoother. No more grinding gears and notchy feel after it warms up.
    I'm still having problem with shifting into 1st and Reverse. But what can I do? It's either a crappy design or poor assembly quality. Helical cut gears should make no noise when properly cut and engaged, but they do. First gear is very noisy. Something else in the transmission makes rattling noise when the truck idles in neutral. There are no miracles. It's a piece of machinery and basic rules of mechanical engineering apply to Toyota design as well. They dropped the ball with their trannies and don't want to acknowledge their mistakes. And I dropped the ball by not test driving it long enough to notice the issues before I bought it.
    Good thing I checked all fluids right away. The rear differential was almost empty. Heck of a quality control. Ohh well, leason learned, life goes on.
    Thanks for all constructive replies.
  20. Feb 21, 2011 at 4:17 PM
    #140
    Gyprat
    Who buys a 4 cyl truck? Maybe someone who thinks with his head, not his dick when making a vehicle purchase.
    Yes I want to get better gas mileage because it's my hard earned money that I have to pay for gas. And gas ain't getting cheaper.
    Go ahead and put a jet engine on yours but don't be telling me what to drive. Priuses are for people who don't know basic math and I'm not one of them.
    And.... if I wanted to buy a truck to haul heavy loads and pull trailers I'd get a full side Dodge or Chevy with a diesel engine.
