How do you drive 5 speed manual?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gyprat, Feb 13, 2011.
  1. Sep 8, 2011 at 10:20 AM
    #161
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    its not that bad for me anymore... only one in a great while it will act up. having a auto locker doesnt help because it loads and unloads the drivetrain funny so its a new learning experience. I agree that the first 5 was bad but i have 48k on it now so its a lot better like its worn in. synthetic did help.
  2. Sep 8, 2011 at 3:56 PM
    #162
    Wally
    Wally Well-Known Member
    Ontario (the metric version)
    07 Access Cab TRD 4x4 6MT 1GR-FE
    So if the spread between the ratios is too big on the way down, as soon as the revs drop low enough in second, slide it into neutral. You probably don't even need to touch the clutch. Use the brakes instead of the engine and bypass the lugging part. When you're slow enough to engage first (barely moving or stopped), clutch it and rev match for the shift if needed. If I'm still rolling, I tend to use the next higher gear and let the torque do the work instead of RPMs so I usually pick 2nd instead of 1st. I don't have the 5 speed but you only have 2 choices ... if you're going around a corner, adjust your speed so that the shift is smooth and matches your available gearing/torque.
  3. Sep 8, 2011 at 5:56 PM
    #163
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    How drive a 5-speed..
    1-Take hold of shift lever and depress clutch
    2-Put in 1st gear
    3-release clutch while stepping on accelerator\
    4-push clutch and release accelerator
    5-pull shift lever into 2nd
    6-continue this process til you reach 5th gear
    To stop vehicle push clutch apply brake til vehicle stops
    Shift into neutral or 1st gear.
    Some procedure for 6 speed
    Hope this helps:):):)
  4. Sep 9, 2011 at 6:53 AM
    #164
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    rofl!:rofl:
  5. Sep 9, 2011 at 7:19 AM
    #165
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    You guys the know the actual 1st "gear" is harder to get in gear because of the diameter of the physical gear inside the transmission. There's a smaller margin for error in attempting to get it to mesh when you put in 1st gear. It takes a little more to get the synchros "jiving" for the smaller 1st gear.
    I don't know if I explained that well enough . . . I KNOW WHAT I MEAN.
  6. Sep 9, 2011 at 8:38 AM
    #166
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I drive a 5 speed like a 5 speed is supposed to be driven. I don't try to put it in a gear it shouldn't be in. When coming to a stop I put the clutch in and leave it in and downshift to the gear I would want to be in if I needed power. That way if traffic starts moving or I need to get out of a situation I'm in the right gear. I don't put it into 1st till stopped or going very slow.
  7. Sep 9, 2011 at 1:35 PM
    #167
    wanderingwayne
    wanderingwayne Active Member
    Wayne
    Pacific Northwest
    Stock 4x4, 3.58 gears, 30" tires, man. hub
    The shudder happens when your RPM's are low and you give it gas of course. I'm not to sure why but that's the way it work. Someone on here can probably come up with a technical reason.
    If you switch to much lower gears you can still get the shudder but it will more than likely be in a higher gear with low RPM's. It should be less noticeable or not noticeable, depending on how you drive, up hill or down hill, etc.
