how do you folks personally set your tire pressures?
Discussion in 'Wheels & Tires' started by toyotahenry, Jan 26, 2022.
  1. Jan 26, 2022 at 3:35 PM
    toyotahenry
    toyotahenry [OP] N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    I know this question is very subjective but i am curious to hear what you folks set your tires at? I know some do the chalk test, some do more PSI up front and less in the rear vice verse and some do same PSI all 4 corners. Once again this question is very subjective so no need to attack each other for their methods. Thanks and looking forward to hearing back!
    pahaf likes this.
  2. Jan 26, 2022 at 3:42 PM
    Anothertacomadriver
    Anothertacomadriver Active Member
    Anthony
    2014 Tacoma V6 Manual
    Usually I go a few psi more than what the door jamb says. If im hauling some decent weight I’ll go 10 psi more in the rears.
    usmc2msu and toyotahenry[OP] like this.
  3. Jan 26, 2022 at 3:55 PM
    Sdtrueblue
    Sdtrueblue Well-Known Member
    Markie B
    San Diego, CA
    2015 DCLB Sport
    6112’s/5160’s Snugtop Rebel NTG’s 265/70/17
    I try to keep it at 34psi in all four. Other than my shell, I'm not carrying any additional weight.
    toyotahenry[OP] likes this.
  4. Jan 26, 2022 at 3:59 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I have stock size tires so I go by the door reading when the tires are cold and it has been sitting for a while. I know I'll be above that when driving
  5. Jan 26, 2022 at 9:45 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    33-35 most of the time in summer
    30-31 in winter
    28-30 when I'm going skiing or know I'll run into snow on the highway
    25-27 if I'm going to be on washboard roads for the day
    If the snow gets deep offroad I'll go down to 18-20
    255/80/17 e-load
    0xDEADBEEF and Bishop84 like this.
  6. Jan 26, 2022 at 9:50 PM
    Bishop84
    Bishop84 Well-Known Member
    I follow this pretty much to the letter.
  7. Jan 27, 2022 at 9:50 PM
    thegrandpoohbah
    thegrandpoohbah Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    Question, do you carry a compressor with you? That seems like a lot of work.
  8. Jan 27, 2022 at 9:55 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    I run 32psi all year round on 265 70 17 sl load tires. Falken wildpeak. I don’t want to run them higher because it will be a stiffer ride.
    for off roading I go down to 15 psi. Doesn’t matter if it’s snow, sand, rocks, or gravel roads.
    35k miles so far and they are wearing down evenly.
    I carry a vair 88p compressor with me and it takes about 2.5-3 min per tire to pump back up.
    Canadian Caber likes this.
  9. Jan 27, 2022 at 10:02 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I think most people who off road and or mess with their tires carry or have some form of a compressor, air down kits and good gauges in their truck. I do.
    Even if one doesn’t off-road, compressor and a good gauge surely isn’t a bad thing to have with you in general I’d imagine
  10. Jan 27, 2022 at 10:06 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Chalk test for a baseline.
    Adjust for loads.
    Adjust for terrain conditions.
    Have tire deflators and on board air. Quick and easy changes.
    Clay7160 and Clearwater Bill like this.
  11. Jan 27, 2022 at 10:57 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Door jamb +2 psi
    Add some add’l pressure in rear if towing the boat a significant distance.
  12. Jan 28, 2022 at 5:39 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I have a crappy one behind the seat but I barely use it. I usually just hit a pay machine at a gas station after I come down out of the woods.
  13. Jan 28, 2022 at 5:46 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm too lazy to do the chalk test so I do the "pull into the garage and the tires get covered in dust" test. Looked even enough so I left them where they were at, which is about 33 all around.
  14. Jan 28, 2022 at 9:08 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I just did a chalk test for the first time and I'm glad I did as my pressures were too high. Previously, I'd just been running (for a short time) what the tire shop recommended. Now that I fairly significantly dropped the pressures it rides a little softer and and my tires should wear more evenly and last longer. When I go offroad I'll still air down. And when I haul anything significant I'll up the pressures guided based on another chalk test (I think one test should give me an idea of a good place to be for future loads, I don't plan to test every single time).
    Clearwater Bill and INSAYN like this.
  15. Jan 28, 2022 at 9:13 AM
    Backdoc
    Backdoc Well-Known Member
    Harford County, MD
    2021 SR5 DCLB
    Bilstein 6112/Eaton Truetrac/RCI sliders Some other stuff
    What tires are you running and at what pressure? I recently put 235/85/16 Cooper STMaxx's on my truck and I am still trying to find the right psi. After reading this forum I think 44psi is way to high. I am going to try 35psi and chalk them and see how they feel.
  16. Jan 28, 2022 at 9:14 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    I go by wear, and recommended pressure
  17. Jan 28, 2022 at 9:14 AM
    thedutchtouch
    thedutchtouch rebmeM nwonK-lleW
    MD
    2013 DCSB TRDOR
    i aim for 32 psi, but i jsut use the regulator that comes on the gas station air machines so not sure if that's super accurate
  18. Jan 28, 2022 at 9:20 AM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    If specific air pressure numbers are important to you, over actual chalk/wear check, then I would suggest ordering yourself a high quality pressure gauge.
    Like owning a torque wrench, every man should own a high quality air pressure gauge (or three).
    Backdoc and EatSleepTacos like this.
  19. Jan 28, 2022 at 9:22 AM
    Duckinatruck
    Duckinatruck Well-Known Member
    2019 OR DCLB
    I use this
    Backdoc likes this.
  20. Jan 28, 2022 at 10:00 AM
    clenkeit
    Colin
    Lakewood, CA
    We’re in similar situations actually. 255/85R16 Yokohama Geolandar MTs for me. I was originally somewhere around 44 like you. I had a hunch this was too high so dropped to 40psi. Then after the chalk test I ended up with 39F/33R. This was with only me in the cab and my “recovery” box in the bed which weighs probably 50lbs. And I think I was near a full tank. When we go camping next time I’ll do it again and suspect I’ll want to up my rear pressures to accommodate for all the supplies as for 2 people and a dog we travel fairly heavy.
    I did the test real quick as I was short on time so I’d actually like to go back and try to dial it in a little more / confirm my findings.
    Backdoc[QUOTED] likes this.
