How do you get to the rear wheel bearings?
Discussion in '1st Gen. Tacomas (1995-2004)' started by wheresthericego, Oct 6, 2009.
  1. Oct 6, 2009 at 2:52 PM
    wheresthericego
    wheresthericego [OP] Active Member
    Raleigh NC
    97 Tacoma, 94 SR5
    I've never had to work on a solid rear axle before. How do you get the axle out to change the wheel bearing? Mine is shot and needs replacing.
  2. Oct 6, 2009 at 2:57 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
  3. Oct 6, 2009 at 6:30 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Take off your wheel and tire.
    There are 4 nuts on the back or your hub (where the axle meets the brake)
    Unhook your brake like that goes into the back of your hub.
    Remove all 4 bolts.
    The axle will then slide out of the housing.
    I did my axle bearing a year or so ago and I had mine pressed out by a machine shop (probably the easiest safest way to do it!)
    And you will probably want to replace that axle seal that rides on the inside of your axle housing.
    Sorry if these instructions aren't to clear but it is very very simple to remove the axle!!
    If you have anymore questions let me know!
  4. Oct 6, 2009 at 6:35 PM
    wheresthericego
    Raleigh NC
    97 Tacoma, 94 SR5
    Thanks. I was looking at everything earlier this evening and know exactly the 4 nuts you are talking about. It didn't look super hard but i've just never done it before.
  5. Oct 7, 2009 at 11:23 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  6. Oct 8, 2009 at 12:35 PM
    Ktaco
    Ktaco Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    your gonna wanna get it pressed on and off for sure. I did mine on my old 96 and the bearings were on there so tight I had to melt the ball bearings with a torch and then cut the inner race off the axle with a torch because it was still seized on. Very finicky work.
  7. Oct 8, 2009 at 12:53 PM
    stucksucksnayota
    Barry
    Ya and what I have found in the past with other things like this is that you or I always end up tearing up something that cost twice as much to replace as it did to take it some where and have them press the bearing off and back on.
    Also I know I said this earlier but probably goin to want to replace your seal that rides in the axle housing when you do this its like 6 bucks and I have had 2 blow out and it sucks because you have to redo the brakes because the diff oil gets all over the shoes.
    But if you dont want to or think you need to them just put grease all over the seal when you put the axle back in and be very careful not to break that seal!!
  8. Oct 8, 2009 at 12:58 PM
    Ktaco
    Oh yeh thats true forsure. And this was in the winter so it was no fun at all. The only reason I did it was because I brought in the axle to toyota to see if they could press the old bearing off and new one on, and they stated moaning about not making any money for doing things like this and that I'm bringing in my own parts. Finally they said the could do it within 2 days.
    2 days for something that was going to take them 20 mons to do and charge me like $140 bucks. haha i told them what I thought of that and went on my way.
  9. Dec 25, 2012 at 12:04 AM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    sub fo I plan to do this this week...
  10. Dec 25, 2012 at 12:23 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
  11. Dec 25, 2012 at 7:55 AM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
  12. Dec 25, 2012 at 8:09 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I replaced the rear bearings on my truck. I built a tool that bolts to the backing plate with a tube through it that the axle shaft went into. At the other end of this tool was a plate and angle iron. The angle hung on the press and then I could just press the axle out. Took a couple days to figure out. It is not a do in a couple hours job IMO.
  13. Dec 25, 2012 at 8:13 AM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
