How do you get your stereo out if you have a airbag key ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaRoamer, Feb 1, 2011.
  1. Feb 1, 2011 at 1:31 PM
    TacomaRoamer
    TacomaRoamer [OP] Active Member
    KenDog.....
    Mayne Island ,British Columbia, Canada
    2006, SR5, TRD-OFF ROAD, 6spd
    Grom Ipod, Leer 100XR Cap.
    Hello everyone, was wondering if anyone knew how to get past the airbag key in order to pull the stereo out, Im trying to install a grom, thnx
  2. Feb 1, 2011 at 1:32 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I don't think it makes a difference.
    To remove the stereo, you pop the climate control panel off (just clips in) and you should be able to remove the 4 10mm bolts that hold the stereo in.
  3. Feb 1, 2011 at 1:36 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Pull the fan speed dial off. Grab the white web you see with needle nose pliers and pull. The AC controld will pop out. Look inside and there are 4 10mm bolts you need to take out. Use an extension. Then the radio will pop out.
  4. Feb 1, 2011 at 1:36 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    That is it .... I have removed mine and have the "key" switch .... not to worry.
  5. Feb 1, 2011 at 1:37 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    i used a plastic spatula i had to gently pry the AC panel off. it came off easy, and then it is business as usual.
  6. Feb 1, 2011 at 1:40 PM
    macgyver
    Brad
    Canton, GA
    Yep I used a puddy knife to remove mine. I tried an awl one time and it slipped and I managed to scratch my AC control bezel :(
  7. Feb 1, 2011 at 1:40 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    I think he is asking because he saw the grom installation video on youtube. If you are doing it that way, I think you can pop off the airbag key the same way as if it was a blank (as in the video). Then with your finger you should be able to pop out the climate controls from the back.
    If not; pop out the blank on the left side of the radio and once you pop out the climate controls from the left side with your fingers, you should be able to kind of grab it from the front, and completely pop it out.
  8. Feb 1, 2011 at 3:40 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    yeah you can just pop the key mechanism out also
  9. Feb 1, 2011 at 4:56 PM
    TacomaRoamer
    KenDog.....
    Thanks everyone for your input, I was able to get a small flathead through one of the cover mounting holes and press down on the clip to remove the climate controls, Im now rockin with my Ipod, CHEERS !
  10. Feb 2, 2011 at 12:47 PM
    joleger
    joleger Well-Known Member
    Saint John, NB
    2008 Access Cab 4x4 TRD Sport
    When I did my stereo I tried to do the same thing as the you tube video...but in my truck the 4x4 switch and the air bag key get in the way.
    As someone said....plastic spatula/paint scraper does the trick.
