How do you identify stock factory front coil spring paint marks?
Discussion in 'Suspension' started by kyleTRDtaco12, Mar 27, 2014.
  1. Mar 27, 2014 at 7:55 PM
    kyleTRDtaco12
    kyleTRDtaco12 [OP] Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    just purchased some very nice factory coil over strut assemblies from another member on here, very low miles off of his 2014 trd sport but unfortunately neither he or i know which coil spring assembly goes on the drivers side to compensate for lean. help is much appreciated because when they arrive they need to go on asap lol
  2. Mar 27, 2014 at 8:08 PM
    kyleTRDtaco12
    Kyle
    New Jersey
  3. Mar 27, 2014 at 8:15 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Cool that you have a cutlass, I like g bodies. I dont have a clue about springs though.
    Maybe go look at your local dealer at the trucks on the lot.
  4. Mar 27, 2014 at 8:40 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    haha thanks for the kind words my man, ill have post some pic up here soon i think lol, G bodies are great cars lol imo haha
  5. Mar 27, 2014 at 8:42 PM
    jrtodd46
    jrtodd46 Well-Known Member
    Kyle
    Jackson, SC
    13 Prerunner SR5 883x/5100
    OME 883x's w/ 5100's
    my 2013 has purple on the driver's side.
  6. Mar 27, 2014 at 8:56 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    hm alright cool, anybody with a 2014 trd sport shed some light?
  7. Apr 2, 2014 at 4:58 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Bumping this... just received the assemblies and they are too close to call on which is longer, ANYBODY with a trd sport with stock suspension care to chime in? Please? The paint markings on the springs that I have are yellow/yellow and white/yellow
  8. Apr 2, 2014 at 6:11 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Would I be correct in saying that since the springs and shocks are already assembled, the overall lengths would be the same, so what I just did was used a micrometer to measure the thickness of one of the coil wounds... Because I was just thinking that overall coil over shock assembly wouldn't define spring rate, the actual spring itself would determine the spring rate... and I found that the one with white/yellow markings was visually and mathematically, very slightly thicker than the one that has the yellow/yellow markings.... so by deduction im lead to think that the spring that's thicker, with the white/yellow markings belongs on the driver's side.... does anyone think I am on the correct track here lol
  9. Apr 2, 2014 at 7:21 PM
    kyleTRDtaco12
    Kyle
    New Jersey
  10. Apr 2, 2014 at 10:51 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    SCRATCH EVERYTHING I JUST WROTE! Ive found out the color codes, for trd sports and limiteds anyway:
    Ok so I went on a late night stroll if u know what I mean lol.... I checked out one of my neighbors tacomas, its either a 2012 or 2013 DCLB limited and his coil spring paint markings are the same as mine, (yellow/yellow, and white yellow) and on his truck the yellow/yellow are on the drivers side, white/yellow are on the passenger side .... so I was like sweet! But I wanted to double check this, so I went around the corner to another neighbors house and he has a 2007 or 2008ish DCLB TRD sport... his springs were Pink/Pink on the drivers side and Green/Gray on the passenger side... I began to sense a pattern here... so it seems like the coil shocks with the same color paint markings go on the drivers side and coils with unlike colors go on the passenger side.... also the paint marks always faced the rear of the vehicle (and if it has the oem yellow bilstein shocks the bar code skew on the shock absorber also is facing the rear of the truck.) So I believe ive figured this mess out somewhat... but this still doesn't explain the paint marks on my original base model springs where all 4 paint marks are a different color lol, idk but im putting the two same color marks on the drivers side and the two differing colors on the passenger since one of my neighbors trucks is exactly the same and the other one follows a similar pattern... I helped myself here but I hope this helps others as well.
    トヨダ MASTER and MTopp like this.
  11. Oct 25, 2015 at 5:39 PM
    OyamaTacoma
    OyamaTacoma Active Member
    Thomas
    Oyama British Columbia
    07 Silver FJ Cruiser 6MT
    Airaid cold air intake Custom sub box Aftermarket stereo Yakima bike rack Blind spot mirrors
    I know this is an old thread but I searched and can not find a definitive answer as to which strut goes on which side. I purchased a used set of struts from a 2011 Tacoma to level the front of my FJ Cruiser and have one coil with pink/pink and the other with red/green on them. If no one knows for sure I will try as Kyle mentioned and put the pink/pink coil on the drivers side. They appear to be the exact same length and only difference I can see is the paint markings
  12. Oct 25, 2015 at 8:09 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Mine is:
    Yellow yellow=driver
    Yellow blue=passenger
  13. Oct 25, 2015 at 10:09 PM
    OyamaTacoma
    Thomas
    Definitely seems to be a pattern here. Solid 1 colour on drivers side. 2 colours on passenger side. I don't understand why toyota didn't mark all the springs the same colours unless their were changes throughout the years. Maybe different colours mean different spring rates??
  14. Oct 27, 2015 at 11:33 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    That's exactly right the different colors mean different spring rates because in the Tacomas the driver side is much heavier than the passenger side because it has the battery that driver and the fuel tank all on the driver side so the driver side front coil spring has a higher spring rate in order to compensate for the extra weight. And I'm pretty sure that two like colors means driver side and two unlike colors mean passenger side regardless of what the colors are that's kind of what it seems like but the base models are a mystery as far as I'm concerned
    MTopp likes this.
  15. Mar 14, 2016 at 1:30 PM
    supra90140
    supra90140 Well-Known Member
    telford pa
    08 dbl cab 4x4 lb trd sport speedway blue tow pkg
    weather tech floor liners
    Just picked up a pair of springs off of a 2016 trd sport and both are grey and red. ???
  16. Mar 14, 2016 at 1:32 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Just guessing here.. but if they're marked identically, they're probably identical.
    Run them in either configuration, both sides will be the same.
  17. Mar 14, 2016 at 1:36 PM
    supra90140
    telford pa
    Well the dealer is installing them when they do the frame so they should know. Was curious about the taco lean tho
  18. Feb 8, 2020 at 7:08 AM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Hey kyleTRDtaco12 - this is an old old post, but the info really helped me, and I wanted to say thanks!
  19. Feb 12, 2020 at 9:14 PM
    RyanTacoMC
    RyanTacoMC 96 Tacoma LX (RIP)
    Bay Area, CA
    2005 Base Access Cab 5-Lug RWD Manual
    4x4 Springs, QA1 TS703s, Rear Sway Bar, blah blah
    FWIW, I'm 2nd Gen Base AC, and driver side has two different colors. Passenger side has no colors?
  20. Dec 10, 2020 at 6:55 PM
    Fight4Function
    Fight4Function Slightly Mutant
    G
    SF Bay Area
    2014 DC TRD OR
    Just swapped out the stock shock assemblies on my 2014 OR and wanted to share.
    Yellow / Brown = Driver
    White / Brown = Passenger
    For this set up, I just remembered "white on right."
    FWIW, when I removed the assembly, the paint markings did face the rear. I
