How do you know if you have a rear TSB done
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JTO, Aug 24, 2010.
  1. Aug 24, 2010 at 6:49 PM
    JTO
    JTO [OP] Well-Known Member
    San Diego
    PreRunner Sport
    I've been trying to read through all these different threads about people getting the rear TSB done but no one ever says what it is. I bought my truck used about 4 months ago and i know its not under warranty anymore due to miles. Is there something that i can look at that will definitively let me know if the TSB was done?
  2. Aug 24, 2010 at 6:54 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    If there are 4 leafs in the spring pack then you have had the TSB done or someone added a leaf. If it's a non TRD Truck but has the Billstein shocks and 4 leafs it's had the TSB done.
  3. Aug 24, 2010 at 6:57 PM
    JTO
    San Diego
    PreRunner Sport
    Dammit. I only have three back there. I keep seeing post about people adding a leaf when doing a lift. If i only have 2 leafs does that mean that i need to add two leafs on each side?
  4. Aug 24, 2010 at 7:02 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    You have three leafs on each side (two spring + 1 overload). You would need to add a single leaf on each side.
    However, aftermarket leafs that add lift will NOT add load capacity like the TSB springs will. Load carrying capacity is affected by leaf spring's spring rate. Spring rate on aftermarket AALs is more designed for articulation/flex rather than load carrying.
    Also: Not to be a dick but you should be more patient and read the stuff you search. All of this has been covered a million times. I'm not indulging any more.
  5. Aug 24, 2010 at 7:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    No. Use 1 AAL per side. Just order the 2" one, instead of the 1.5" one.
