how do you know when to change rear brakes on 05 tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jerimiahcontreras, May 23, 2016.
  1. May 27, 2016 at 6:05 AM
    coolreed
    coolreed Well-Known Member
    Reed
    OKC
    2019 Toyota Tacoma TRD Pro
    Goodyear Wrangler Dura Track Pro Tires, K&N Cold Air Intake, Pedal Commander.
    With regard to pounding on the brake drums to release the drum. Pounding on anything with a hammer will almost always get one in trouble and should be a red flag to your brain something is wrong.
    That being said,....I have no issue with 'taping' around, as opposed to pounding, the brake drum to get it to release or separate from the brakes shoes due to debris between the shoe and the drum.
    But the best method for Taco brake drum removal is using the bolt method to separate the drum, if the drum is bound up.
  2. May 27, 2016 at 6:11 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    why do people keep recommending this ?????????
    all toyota drums and rotors have two bolt holes you screw 2 M rated bolt into and it
    presses the rotor or drum off with ease. no need for gorilla action whatsoever
  3. May 28, 2016 at 7:28 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Because it works and the threaded holes often rust and fail...
  4. May 28, 2016 at 8:42 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Just to play the devils advocate.
    I have never seen one rust out and fail. If you back off the brake adjustment properly they will usually come off by hand. Sometimes there is a rust build-up on the hub center hole that a wire brush will take care of and occasionally I will resort to using the bolt holes.
  5. May 31, 2016 at 9:34 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    see my post on page one of the thread
    also they'll be rusty so put a little drop of 30W in the hole before you put the bolt in
  6. May 31, 2016 at 12:22 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i think pounding on the drums risk the hydraulic cylinder..you start pulling the shoes which torques on the cylinder..
    i hate doing drum brakes. i'm just not great at getting that perfect initial adjustment. plus all that crap that waffs out of the drums..gag. cant be great for my lungs.
  7. May 31, 2016 at 5:38 PM
    hetkind
    Howard
    Johnson City
    I used to do several dozen drum brake jobs a week, never busted a wheel cylinder removing a drum.
    Howard
  8. Sep 3, 2016 at 4:14 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    I keep my rear's adjusted, which will wear them out quicker, but I like a short trigger brake pedal. I think you should look at them once in a while anyway. They can always use cleaning, if nothing else. And if you take the drums off once in a while, they will always come off easily.
