how do you know when U-joints have enough grease?
Discussion in 'Technical Chat' started by aficianado, Aug 3, 2013.
  1. Aug 3, 2013 at 7:55 PM
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    change my oil today. realized i havent lubed my driveshafts in a long time. dug out my JUNK grease gun, loaded it up and pump "some" into every zerk i could find. i found 5 total.
    i just pumped until i heard that slight lip smacking sound...any better way?
    and i need a new grease gun. i have one of those mini ones. the grease is much more expensive, and it really sucks. it leaks and is a mess loading..
    any better options? what grease gun do you have? do you just store them and they dont leak?
  2. Aug 3, 2013 at 9:19 PM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    just get a pistol grip grease gun and use a good grease that's made for u joints. and before you grease check the shaft for loose cap bolts and loose u joints
  3. Aug 3, 2013 at 9:38 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Its full when it starts to slightly come out of the seal.
  4. Aug 3, 2013 at 9:47 PM
    aficianado
    back to bone stock.
    Thanks bud. I might add some more tomorrow.
  5. Aug 5, 2013 at 12:01 AM
    SFerrari
    SFerrari Member
    I changed my rear ujoints about a week ago. I bought one of those small grease guns from napa just to top the ujoints off and I was actually happy with how it worked. I bought refill cartridges for it but I read the instructions and it turns out you don't need to use the cartridges. You just take the top/pump end off and jam the open end of the canister into a tub/bucket of grease and pull the handle back. It'll fill the cylinder with grease. When it's full you just lock the rod back, screw on the top, release the rod, and push the rod back into the cylinder.
    Are the little canister refills really that expensive? Do you really use that much grease? Where does yours leak from?
  6. Aug 14, 2013 at 7:06 PM
    Mrogers33
    Mrogers33 The way is open, the time is now
    Columbus, OH
    03 doublecab 4x4 grocery getter
    seemed appropriate to ask this here, does anyone else have a grease gun as leaky as this? I keep it in this bucket cause the liquidy red shit constantly seeps out of any small opening but the actual thick red grease (Mobil1 synthetic) doesnt leak out of the nozzle. I don't think I loaded the gun wrong, i just threw in the tube o' lube and released the plunger thing on the end to push it out. It was a $20 POS from auto zone but really is this normal for a cheapo or did I fuck up?
  7. Aug 14, 2013 at 7:17 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    If you don't use your loaded grease gun often the oils in the grease can separate and leak out of the gun. I bought a grease gun from Tractor Supply Company because our family farm is tax exempt there. As for adding grease to u joints, add grease until new stuff comes out. Grease breaks down so by pushing out the old all new takes its' place.
    Governor likes this.
