How do you level the Cab of the truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rick007, Jun 22, 2008.
  1. Jun 22, 2008 at 8:52 PM
    Rick007
    Rick007 [OP] New Member
    Houston, TX
    2000 PreRunner Extended Cab
    I purchased a used 2000 extended cab, and the cab is .75" lower on the passenger side. Is there an adjustment to level the cab on the frame?
  2. Jun 22, 2008 at 9:39 PM
    RoadKill
    RoadKill Northern Alliance: padawan
    North of the border
    First gen 4x4
    285x70x17 offset rims+ 1.5 spacers, rear Timbrens + 3 inch lift add a leaf, Sway-a-way coilovers + camburg control arms, Fender flares (2.5 inch), clear lights, headers, sliders, roll bar
    Check your cab rubber mounts on frame, is it lower compared to the bead?
    If not, check rear suspenssion, you could have a broken leaf, probly master leaf and right smack in the middle @centering pin
  3. Jun 22, 2008 at 9:46 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    strange that its on the passenger side...i think normally the taco lean bites the drivers side :confused:
  4. Jun 23, 2008 at 7:36 PM
    Rick007
    Houston, TX
    I am going to check to see if either of those options solve the problem.
