How do you like this lift setup?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by w4lter, Jun 10, 2010.
  1. Jun 10, 2010 at 10:15 AM
    w4lter
    w4lter [OP] Well-Known Member
    Omaha
    TRD Sport
    Westin bullguard, Steelcraft 3" Nerfbars, Bilstein 5100s all around -front set at 2.5", toytec 2" AAL, Wickedflow muffler, 265/70/17 Destination ATs.
    After lurking on these forums I think I finally have my setup. Bilstein 5100s in the front and back with rear 1.5' add-a-leafs. I would like to get 285/70/17 tires if they won't rub or should I stick with 265/70/17s?
    With the add a leafs coming should I get the rear suspension TSB? I need it, I had my truck loaded up with only about 700 lbs (passenger +cargo) and hit a rut - my truck bottomed out so hard I thought it was going to explode.
    ANY tips/suggestions are appreciated. I've tried hard to figure all this stuff out but I really don't know what I'm doing.
  2. Jun 10, 2010 at 10:21 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    The TSB's in the rear will stiffen your ride a little but they are well worth it. I had them done on my 2006 plus the AAL and was very happy. The 5100's are a great way to get lift without breaking the back. It will probably take a good bit of trimming to fit 285's with a 2.5" lift. I had 3" and still did a lot of trimming to fit 285/70/17.
  3. Jun 10, 2010 at 10:23 AM
    CRfofiddyF
    CRfofiddyF Well-Known Member
    AZ
    07 TRD DC 75Kmi
    This is the plan I have to lift my 07 DC. I will not got 285 though. Please post pix when completed.
  4. Jun 10, 2010 at 10:24 AM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    That's the same lift that I'm going to do. The only difference is that I will also be adding Eibach coils up front. I will be setting the Billies at 0 since the Eibach's are longer than my factory coils. I should get a little less than 2 inches of lift up front from the coils without having to compress them with a higher 5100 setting.
  5. Jun 10, 2010 at 10:28 AM
    KrackHouse
    KrackHouse Well-Known Member
    I was thinking about doing the same.
    Which springs are you planning on buying? (link, website)
    Where is the best place to buy the shocks?
  6. Jun 10, 2010 at 10:42 AM
    28Gauge
    Brian
    Grapevine, TX
    06 PreRunner SR5
    I'm going to get my springs from http://www.toyteclifts.com. Their is only one set of Eibach's for 2nd gen. For the rear, I'm going with the 1.5 inch add a leaf for TSB springs. I don't have the TSB springs, but these will still work. Toytec is an official vendor on TW and they offer members a 5% discount. You have to PM them to get the discount code.
  7. Jun 10, 2010 at 10:49 AM
    w4lter
    Omaha
    TRD Sport
    Am I alright without new coils? The Bilsteins are backordered at toytec. If I order them now, any idea if they will come in by August?
  8. Jun 10, 2010 at 11:50 AM
    KrackHouse
    Thanks for the info.
    I will get those ordered ASAP.
  9. Jun 10, 2010 at 12:46 PM
    JohnnyK.
    JohnnyK. Wheeler's Offroad Tech Rep Vendor
    Johnny
    Grants Pass, OR
    The Bilsteins are a great way to go! (we have them in stock for 2nd Gen Tacomas) The AAL will stiffen up the rear end and help prevent bottoming. But for when you do bottom out, to soften the blow, look into a set of rear Super Bumps.
