How do you listen to music with your iphone in your taco?
Discussion in '1st Gen. Tacomas (1995-2004)' started by scshtx, May 11, 2017.
  1. May 11, 2017 at 1:16 AM
    scshtx
    scshtx [OP] Well-Known Member
    San Marcos, TX
    2002 DC 4x4 TRD
    With the stock radio system. Today I bought a cassette to AUX and it went to static within an hour so gonna have to return it. What method do yall use to go about listening to music from your iphone/phone or mp3 whatever yall use in your taco, with the stock system?
  2. May 11, 2017 at 1:22 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    You can modify your stereo and add an aux connector.
    https://www.tacomaworld.com/threads/cheap-mod-diy-aux-input-in-a-2005-2008-factory-head-unit.161339/
    Or you can replace your radio. Decent ones with bluetooth, aux and more power are available pretty cheaply today.
    You can go single din or double din (the size of the radio) with an installation kit.
    https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=scosche+tacoma&rh=i%3Aaps%2Ck%3Ascosche+tacoma
    There are plenty of stereo related threads here. have a search.
  3. May 11, 2017 at 1:24 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Sorry those kits are for 2nd gens. Check out Scosche's web site, I'm sure they have one for your truck to. If not try Metraonline.com
  4. May 11, 2017 at 2:33 AM
    Indy
    Indy Master of all I survey.
    Spend about $40 on a bluetooth transmitter and be done. No wires betweenyour phone and radio or the transmitter and radio. You'll be able to take it from vehicle to vehicle, sounds as good as an fm station. Spend less on one that plugs into your headphones jack but it won't sound very good. Spend even less on ebay generic and it will sound pretty bad.
    Or spend more on a bt head unit, and an hour or 2 doing the swap.
    Cassette adapters, id rather listen to wind noise.
  5. May 11, 2017 at 2:39 AM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
    I use https://www.usaspec.com/p-327-pa15-toy.aspx. Not cheap, but it works like a champ and also charges my iPhone. I have one of the older ones that has the 30pin iPhone connector . I just added the Apple 30pin to lightning adaptor and it works great with my iphone6s
  6. May 11, 2017 at 12:08 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I replaced the HU with a half way decent Pioneer unit for $90. It has a USB port to connect my iPhone. Plays music, charges the phone and displays artist/album/song info.
  7. May 11, 2017 at 12:47 PM
    thej
    thej Active Member
    north idaho
    2003 ext cab TRD
  8. May 11, 2017 at 12:51 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Bluetooth distorts audio horribly. Aux/USB port is the way to go.
  9. May 11, 2017 at 1:23 PM
    Indy
    I think horribly is a bit strong unless there is something wrong with the hardware. Bt isn't lossless but the difference is fairly minor. I doubt to many people get concert hall thx quality sound from their 20 year old tacoma stereo.
  10. May 11, 2017 at 1:26 PM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    I got an aftermarket head unit for around $150, then installed it myself and now I have both an AUX input and Bluetooth. I use the Bluetooth unless I need to charge my phone and then I'll plug it in through the USB AUX input.
    99SuperTaco4x4 likes this.
  11. May 11, 2017 at 1:36 PM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    https://www.amazon.com/dp/B01EUZ8NQ8
    $24 and the time it takes to pull your radio. I got the same thing for my wife's scion...despite the mixed reviews, I have absolutely no complaints. If it doesn't work for some reason, you can return it.
  12. May 11, 2017 at 1:40 PM
    TashcomerTexas
    In a sense. @Blackdawg knows the whole stats on audio and whatnot. But having both I can hear a big difference in audio quality.
  13. May 11, 2017 at 1:53 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Do you have a link for the $40 one?
  14. May 11, 2017 at 2:10 PM
    dgshelto
    dgshelto Well-Known Member
    David
    Colorado
    2002 Tacoma Base
    Is it cassette only or does it also accept CDs? Unless it doesn't matter...maybe someone can comment.
  15. May 11, 2017 at 2:18 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I replaced the HU with used double din almost three years ago and haven't had any problems since. I plug my lightening cable right into the USB jack and rock on.
    :broccoli::headbang::jellydance::kona:
  16. May 11, 2017 at 2:22 PM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
  17. May 11, 2017 at 2:23 PM
    dgshelto
    David
    Colorado
    2002 Tacoma Base
    I think links and/or pictures would be appreciated in this thread :thumbsup:
  18. May 11, 2017 at 3:18 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Blue tooth is horrid.
    But i can't stand even Youtube data compression..so i am in the minority.
    I'm also guessing you're shooting yourself in the foot from the get go with some crappy MP3 with a low bit rate anyways, so you probably won't see a difference. If you are playing high bit rate files, the difference would be VERY noticeable.
    TashcomerTexas likes this.
  19. May 11, 2017 at 4:36 PM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    Adam
    Sacramento
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    This is what I did as well, a double din unit paired with a rear backup camera. Total: $175
  20. May 11, 2017 at 5:26 PM
    Indy
    http://www.bestbuy.com/site/scosche-btfreq-bluetooth-fm-transmitter-black/5577305.p?skuId=5577305
    Search for "blutooth fm" and you'll get options.
    I used a jabra cruiser (cruzer maybe) for years, until i would get around to doing the hu. Then it would go back in the closet until i changed vehicles and needed it again. Then my wife used it until last year when it finally died. 20ish on ebay. I bought her one of the best buy ones to replace it and it works well. She listens to audiobooks all the time.
    I've had $5k stereos and installed more systems than i can count. Ive also had bone stock toyota. Bt won't sound any worse than an fm station and as far as convenience its hard to beat. If you're like me and steam pandora all the time, you're already using compressed audio.
    No matter how pure your signal is you're not going to get much better sound out of 20 year old paper full range speakers being pushed with 5w of factory power :laugh:
