How do you lock the rear diff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TopTeke, Jul 21, 2009.
  1. Jul 21, 2009 at 5:34 PM
    TopTeke
    TopTeke [OP] Active Member
    Ventura, CA
    07 PreRunner 6spd. Access Cab
    I bought my Prerunner used and it didn't have a manual. I searched for this answer but it's not coming up.
    How do I lock my rear diff? Is it the button under the steering column that kind of looks like " (_!_) " ? If not, what is this button for?
    Thanks!
  2. Jul 21, 2009 at 5:45 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    that butt button is to reset the tire pressure monitor system.
  3. Jul 21, 2009 at 9:43 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    :thumbsup:
  4. Jul 21, 2009 at 9:46 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    I think it also resets the req'd maint. light.
  5. Jul 21, 2009 at 10:00 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    that is reset by the ODO peg
  6. Jul 21, 2009 at 10:11 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    yep..... look at that pic. If you have that button to the left of the steering wheel, then theres your answer. If theres no button, then you dont have a locker unfortunately.
  7. Jul 22, 2009 at 6:51 AM
    carmellocafe
    KEVIN
    N. California
    You're right jhodge. I dunno what I was thinkin.:eek:
  8. Jul 22, 2009 at 7:06 AM
    DDD
    Derek
    Santa Clarita, CA
    I think you put this on the rear diff.
  9. Jul 22, 2009 at 7:07 AM
    jonny
    jonny Betty White Edition Heep ZJ
    you cold haha
    well said sir
  10. Jul 22, 2009 at 9:59 AM
    LS1Steve
    LS1Steve Well-Known Member
    Just curious, what are the limitations on pushing that button? Below 5mph only or in Neutral? Will it stay locked if you accelerate past 5mph to saaaay 60 on the sand? Can I unlock it at speed?
  11. Jul 22, 2009 at 10:11 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    yes you can unlock it at any speed. I use mine on the drag strip and have no problem unlocking it at 90mph.
  12. Jul 22, 2009 at 10:12 AM
    matthew5olson
    matthew
    pittsburgh, PA
    just don't be spinning the tires when you go to lock it
  13. Jul 22, 2009 at 10:22 AM
    jonny
    BS
    you trap 76 mph
    haha jk man
