How do you measure the LEVELness of a truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skistoy, Mar 10, 2011.
  1. Mar 10, 2011 at 5:47 PM
    skistoy
    skistoy [OP] Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    With many using 5100s and lift kits, etc
    and hearing how a truck sits nose high, or back end high,
    I was just wondering how people actually determine
    how level their truck sits.
    weather using measurements, actual levels, just eye-ball it.
    Just wondering? I measured the flat part of the frame.
  2. Mar 10, 2011 at 5:48 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    started another thread on the same topic?
  3. Mar 10, 2011 at 5:49 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Center of hub to fender.
  4. Mar 10, 2011 at 5:49 PM
    skistoy
    Western New York
    yes , this one is questioned better
  5. Mar 10, 2011 at 5:50 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    I read somewhere to measure from the bottom of the rim to the bottom of the fender well. Not ground to fender. So that's what I do.
  6. Mar 10, 2011 at 5:50 PM
    skistoy
    Western New York
    See, i dont think the fenders are cut equal
    but i may be wrong
  7. Mar 10, 2011 at 5:52 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    ^this
  8. Mar 10, 2011 at 6:05 PM
    skistoy
    Western New York
    thats the usual way
    i was just wondering if anyone else did something different
  9. Mar 11, 2011 at 10:30 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    The reason I gave you the measurements at stock in the other thread was so you could answer your own question. If the truck sits "level" when new (without rear leaf TSB), then you can measure the height of the rear fender and front fender to see about how much the rear sits higher than the front at stock (I'll post the link again for those reading this but didn't read the previous thread: http://www.tacomaworld.com/forum/2n...height-front-back-difference.html#post2846362). Now whenever making a change, you'll know you're sitting level if the rear is still sitting an inch higher than the front.
  10. Mar 11, 2011 at 10:32 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    I agree with this. I just eyeball it.
  11. Mar 11, 2011 at 10:39 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Measure all you want, if it doesn't look right, it doesn't matter what the measurement is. I think 'level' when measured looks nose high. Others would disagree with this.
  12. Mar 11, 2011 at 3:24 PM
    skistoy
    Western New York
    :facepalm:
    this is a general question im asking,
    I dont think the truck sits level when NEW.
    ( hense why they make LEVELING kits )
    so having the measurments when new is of no help.
    P.S. how can i answer my own question, when the question
    is looking for the response of others.
  13. Mar 11, 2011 at 3:26 PM
    skistoy
    Western New York
    I agree, when the fender heights are equal heights
    i think it look nose high also
  14. Mar 11, 2011 at 8:00 PM
    05Moose
    Jim
    I see your point, sorry. I think most people are eyeballing it (basically a visual WAG:D). While I have the measurements, I personally eyeball it. And I do this in other places too. You should see my Northern California Tacoma sticker on my rear window. I "eyeballed" it, so it tilts down on the right.:D
  15. Mar 13, 2011 at 1:38 PM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    Down here we just stick a lawn chair sideways in the bed. If the dip runs out both sides of the mouth equally. She's level!
  16. Mar 13, 2011 at 2:17 PM
    skistoy
    Western New York
    hahaha
    now thats what im talking about
  17. Mar 13, 2011 at 2:28 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    How about a carpenter's level on the bed rails?
    mahaloTaco likes this.
  18. Mar 13, 2011 at 2:38 PM
    P-Hill Tacoma
    P-Hill Tacoma Well-Known Member
    Missouri
    2010 DC Short Bed 4WD Off Road Barcelona Red
    Fr Bilsteins@1.75", Rr Bilsteins w/ 1.5" AAL & RideRite Airbags, Truxedo Lo-Pro Tonneau, Step Tubes, 1.25" Spidertrax
    You can measure from the ground to the bottom of the frame on the flat part between the wheels. When it's level there it's trully level but it will look nose high from the side especially the sport because of the shape and your use to seeing the back higher.
  19. Mar 13, 2011 at 6:35 PM
    skistoy
    Western New York
    i have thought of this also.
    you would think the design of the bed should have them level to ground
  20. Mar 13, 2011 at 6:37 PM
    skistoy
    Western New York
    this is how i gauged how level my truck is
    and believe this would give you the best level indication of the truck.
