how do you navigate; cell phone?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Apr 19, 2020.
  1. Apr 19, 2020 at 8:44 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    Is the best way to do it with a RAM mount using a cell phone with unlimited data plan?
    After a recent trip I am realizing my current setup may be flawed.
    With a 4GB cell plan currently, a friend recommended I upgrade to unlimited data, which he has and says is worth the extra monthly cost.
    I think it goes up from $50/mo to $65/mo.
    Normally I turn apps on and off manually to save data, but it's a pain and still reaches the limit anyway.
    My current GPS, an old Garmin Nuvi, has tried taking me off course maybe 7 times already, even with updated maps.
    Trying to get with the modern times here; seems like maybe the way nowadays is Google Maps
  2. Apr 19, 2020 at 9:30 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Google maps for navigation. I typically use ~ 300mb of data per month running it.
    I also have a Gaia gps subscription that I use to plan out trips and look at maps
  3. Apr 19, 2020 at 9:42 PM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Google maps. There really isn’t a better way to navigate these days.
  4. Apr 19, 2020 at 9:58 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    If you don’t currently need unlimited data I would just get a new accurate Garmin gps. What you would pay for unlimited data for one year would buy a new Garmin. You’ll probably get a little bigger screen than your phone which is nice too. Also when using your phone as a gps it can be a hassle in city traffic trying to find a location while talking on your phone.
    I use my phone on occasion as a gps And it works great but I prefer my regular gps.
  5. Apr 20, 2020 at 12:34 AM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    Never had many issues with Apple Maps. The newest update is great.
  6. Apr 20, 2020 at 1:55 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Apple maps have stepped it up. They do have few little things that i like over google. Mostly the traffic light icons and she tells you to turn at light instead of saying next “left or right “ I prefer google of the map layout on screen I use it alot to look for fishing ponds all over the place
  7. Apr 20, 2020 at 2:05 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    I’m old and cheap. Still rocking a Garmin GPS. It’s easy on the data plan. The device I use is a Nuvi 760.
    Sprig, spitdog and Harry2015 like this.
  8. Apr 20, 2020 at 3:53 AM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    I use all of the above.
    For driving, I have a Garmin "Drive 51" GPS that I picked up refurbished for cheap and I also use a combination of Waze & Google Maps(I like Waze on the road better). Before every trip, I'll do a map recon via google maps and I keep an atlas in the truck just in case. I tend to hit a lot of dead cell spots and the manual or non cell dependant options are useful.
    For work, I use a combination of Avenza Maps(gives me MGRS and requires a PDF map loaded in), google maps, a Foretrex 601, and a paper map.
    jrallan26 likes this.
  9. Apr 20, 2020 at 4:26 AM
    POS VETT
    POS VETT Well-Known Member
    Tom
    Columbus OH
    2020 Tacoma SR 4x4 V6 DC
    I use Waze. Before the pandemic, I drove about 125-135 miles on average daily mostly inside city limits for work. Waze has been my go-to navigation with Google Maps as a back up. One part I need on a navigation system is real-time traffic data (directions are secondary), meaning that it needs to be connected to a live source of traffic data and changes in map data reliably at all times (annually updated map data could turn into a fiasco in the daily practice). In my experience, any navigation system has its own flaws in different aspects. Pick one (or two) and familiarize yourself with them.
  10. Apr 20, 2020 at 4:58 AM
    Yamabushi
    Yamabushi Member
    I put in a carplay enabled head unit and use Google Maps or Waze. I like it much more than mounting my phone for the larger screen if nothing else. I may be underselling that - it's divine.
    I've never looked at the data usage for GPS. I believe with Google Maps you can save maps locally which might save some data.
    Newlife likes this.
  11. Apr 20, 2020 at 5:00 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    iPhone google maps on road if I really need help as my memory works for most trips.
    Off-road I always print or buy a real forest service or all trails type map as cell coverage often disappears. Always have a compass
    Garmins/Sat Nav systems are great too but I'm old school off-road and want to pre-plan on paper.
  12. Apr 20, 2020 at 5:13 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    For on-road nav I always use Google Maps. If you are worried about data, you should try downloading offline maps of your route while you are still connected to WiFi. Thats a big saver
    Old school dedicated GPS units tend to use more of a set route from A to B, whereas Google can access its traffic data to find the most efficient route at whatever time you're traveling.
    As far as mounting you can do a solution like the picture you posted, but you should look up the A-pillar RAM mount as well. I think thats a really clean solution because it puts the phone right near your line of sight, but doesnt obstruct view if you get it positioned just right. And the RAM mount catalog is just about endless, so you can pick whatever kind of mount & arms works best
