How do you non-slider guys jack up your truck for tire rotation?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 80sforlife, May 31, 2017.
  1. May 31, 2017 at 12:55 AM
    80sforlife
    80sforlife [OP] Well-Known Member
    2017 Toyota Tacoma DC TRDOR 4x4
    I'm sick and tired of the dealership and Discount tire scuffing up my wheels during tire rotation. How do you non-slider guys jack up your truck on one side so both tires are lifted off the ground? Articulation is great for off-roading, not so much when you're trying to get both tires off the ground for a tire rotation.
  2. May 31, 2017 at 1:04 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Use jack stands.
  3. May 31, 2017 at 1:15 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    If you lift the truck by the slider, you have to jack it up pretty high to get all the droop out and get the tires off the ground. Use the stock jack on the rear axle, then set it down on a jackstand, just high enough to get the wheel off. then pop off the wheel and jack up the front leaving the rear axle on the stand. Its not rocket science.
  4. May 31, 2017 at 1:33 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    jack stands, together with a floor jack
  5. May 31, 2017 at 3:46 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I use Discount for free rotations. Not sure how they are scuffing up wheels just doing a rotation. I bought tires there so I also get free balancing. Discount that I use gets real busy so I just rotate every 10k which I think is plenty over tires life.
  6. May 31, 2017 at 4:22 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Buy a floor jack and jack stands... if you're off roading should have a full size spare so really just need a jack. If your jack is to small I use wood sometimes but just go to harbor freight and pick you a decent jack.
