How do You program keyless entry on 2007 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jack Patton, Mar 14, 2008.
  1. Sep 10, 2009 at 5:20 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    Does this procedure program a new remote control to work with the truck or does this do something else?
  2. Sep 16, 2009 at 8:20 PM
    Spootypuff
    Spootypuff Well-Known Member
    Jacksonville, FL
    SWB Sport Double Cab SB 4x4
    Satoshi
    It programs a new remote for your truck. I just did it for two and it worked perfectly :D
  3. Aug 10, 2011 at 5:56 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    I took a 5 Hr energy, It Worx for me:D
    Oh and reprogramming worked :p
  4. Oct 5, 2011 at 1:11 PM
    Manwithoutaplan
    ID
    the stealership can shove that 100 bucks up their ass for charging me :D. FIxed it for free :D
  5. Apr 21, 2012 at 5:52 PM
    Aod
    Aod Ex STi enthusiast
    B.
    NorCal/Bay Area
    2023 Tacoma TRD Pro
    I just got a third remote for my kid and haven't programmed it yet. Does anyone know if the Tacoma supports three remotes linked to one truck? If so, can I just add the third to the existing two or do I have to reprogram all three. It's actually a used key fob and I think it was registered to another tacoma also if that helps any.
  6. Apr 21, 2012 at 9:03 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    This works on an 08.
  7. Jun 6, 2012 at 6:27 PM
    radjeeper
    radjeeper New Member
    Utah
    '06 Tacoma 4x4 TRD
    Old Man Emu Suspension, ARB Bull Bar, Warn 8000 Winch, Leer Shell, AR Black Aluminum Rims, Goodyear Tires
    I just purchased an '06. Went through the programing steps as outlined. What I'm after is to get all 4 doors to unlock using the remote. Currently only the drivers door unlocks. However, all the doors lock. What up with that?
  8. Jun 6, 2012 at 6:58 PM
    Sly Dvl
    Sly Dvl New Guy with an Old Hat
    Kevin
    Fergus, ON, Canada
    '13 TRD
    Pressing the "unlock" button on the remote a second time (within 1-2 seconds of the initial press) usually unlocks all the doors. This is standard programming for most manufacturers. The theory being if you're approaching the vehicle alone you don't want to unlock all the doors for fear of an intruder lurking nearby...
  9. Jun 6, 2012 at 7:49 PM
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    Whoa does anyone know if this works on a 09?
  10. Jun 7, 2012 at 10:21 AM
    radjeeper
    Utah
    '06 Tacoma 4x4 TRD
    Thanks...I feel much safer now. :)
  11. Jun 7, 2012 at 11:03 AM
    opiestaco
    opiestaco Well-Known Member
    Wolcott, VT
    05 Tacoma SR5 V6 6speed 4X4
    Lifted with 285/75r16
    I have an 05 Sr5 access and it came with 1 black key. Does this program only work with the key fobs or will it program an actual key? And will a key fob even work with my truck?
    Thanks,
    OPie
  12. Jun 19, 2012 at 11:05 AM
    michaelhorn
    michaelhorn Active Member
    Central Minnesota
    V6 DCLB
    Day One - Tonneau Cover Day Two - Weather Shield Floor Mats
    Thanks, just canceled my service call today by using the code to reprogram my remote on my 3 week old 2012 tacoma.
    Worked fine.
  13. Jul 22, 2012 at 6:09 PM
    harley
    harley Member
    harley
    Houston
    07 SR5 4WD 6SM
    3 in. lift, LEER topper, weathertech mats, AVS bug shield and window visor, aux port, dipped badges and wheels, black ebay headlights
    Works for 07 6SM, thanks
  14. Aug 12, 2012 at 6:03 PM
    Rock501
    Rock501 Well-Known Member
    Stafford, Texas
    07 PreRunner, TX edition with factory 20's
    This worked for me as well on my 07 Texas Edition
  15. Oct 14, 2012 at 9:43 AM
    #35
    Steelerdru
    Steelerdru New Member
    Drew
    Pittsburgh
    07 Tacoma 4dr Long bed
    These steps work for 07 Tacoma, thanks to all for posting these
    Past instructions:
    Start with the key out of the ignition. Open the driver door (all other doors are closed). Driver door is unlocked (other doors don’t matter).
    2. Perform these steps within 5 seconds
    a. Insert the key into the ignition (don’t turn it) Pull key out
    b. Insert the key into the ignition (don’t turn it) Pull key out
    3. Perform these steps within 40 seconds
    a. Close, then open the drivers door.
    b. Close, then open the drivers door.
    c. Insert the key into the ignition (don’t turn it) and pull it out.
    4. Perform these steps within 40 seconds
    c. Insert the key into the ignition and leave in the ignition.
    d. Close the drivers door, Turn the ignition to ON (as far as you can go without cranking the engine), then back to off .
    e. Remove the key from the ignition.
    5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
    6. Perform these steps within 40 seconds
    a. Press the lock and unlock buttons on the transmitter simultaneously for 1.5 seconds
    b. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
    7. Open drivers door
    Hope this helps, I've come across the need for this type of programming on other vehicle before and I have referred to this website with success before.
  16. May 20, 2013 at 6:27 PM
    #36
    Khoolguy
    Khoolguy Active Member
    Diamond Bar, CA
    TRD Offroad
    I get to step 6 follow the procedure but it always performs door lock twice and can't get the remote to program. I got a 2011 TRD access cab
  17. Aug 16, 2013 at 9:55 AM
    #37
    spieler
    spieler Well-Known Member
    Jonesborough, TN
    13 white DCSB SR5 4x4
    3" Lift kit/265 Duratracs/SCS Stealth 6 matte black wheels, OEM White grille switcheroo, TRD skid derped white, CSjumper drtl map dome parking lights fog light bulbs, Lifetime LED headlights, **Reverse light mod, Foglight anytime Mod, Trimmed mudflaps, Fully Debadged, 3rd brake light cover by well...me, Liquid Innovations black carbon dipped front emblem, G-Tek Fab diamond plate white door sill protectors, SOS Bolt-on Sliders bedlined, MattGecko rear window security bar, Hardwired Radar Detector w/custom sucker mount, Horse Stall Bed Mat, Audiocontrol LC2i with custom mount ACR-1 remote, Custom sub box behind drivers rear seat, Mag light holder behind seat, Center console organizer , Passenger seatbelt flapper fix, Tailgate anti-theft Mod, Bed storage Locks Mod, hygieneboy ghetto gutter grille guard
    Works as well on a 13, thanks a ton for this!
  18. Aug 16, 2013 at 10:04 AM
    #38
    Manwithoutaplan
    ID
    this is great thread :thumbsup:
  19. Aug 16, 2013 at 10:10 AM
    #39
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    This worked on my '11 AC (white gauges)
  20. Aug 16, 2013 at 10:15 AM
    #40
    Manwithoutaplan
    ID
    may i ask what the white gauges have to do this??
