How do you rate 05-07 Taco Sound System?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Wookie, Nov 9, 2007.
  1. Feb 3, 2008 at 5:36 PM
    #41
    ED R
    ED R Well-Known Member
    I have the double cab, and to my ears the mixes are all wacked- there's no midrange and sopme tracks that are prevelant in a two-speaker setup are buried in this one. I'm not too happy about it.
    By th eway, it's not the SIZE of the magnet that really matters, it's the STRENGTH of the magnet. GRanted, those magnets look like they'd be hard-pressed to pick up a pin, but still..
  2. Mar 24, 2009 at 10:24 AM
    #42
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    whats with the stock mounts? do they not seperate from the stock speaker? i can get last years model of pioneers (or sony xplod/nexxtar if i wanted but ill go for the pioneer) for half price cuz the new models came in yesterday. anyways id like to buy the pioneer set before someone else but dont have any local shops to buy a mounting bracket kit. could i use the ones that came with the stock speakers of make my own from a sheet of mdf or something?
  3. Mar 24, 2009 at 10:35 AM
    #43
    Cars0n`
    Carson
    Alberta
    03 2.7L 4x4 5spd
    sorry my bad i meant to post that in the DIY link to the speaker upgrade
  4. Mar 24, 2009 at 10:42 AM
    #44
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I upgraded my HU first, and the sound was a bit clearer. Then I put in aftermarket speakers which made a noticeable difference. Then I added an amplifyer and the difference is AMAZING. The amplifyer is not a must have, but I looked at this way: If you put after market speakers that can put out 150W, but are only getting 50W from the HU, why not let the speakers work they way they were designed to with an amplifyer. And the difference is amazing. The sound quality at low volumes is not too big of a difference but with mid to high volume it is amazing
  5. Oct 2, 2009 at 9:19 PM
    #45
    CyberDyneSystems
    CyberDyneSystems New Member
    So in real life I'm a theatre technician and Audio engineer,.
    I'd just to explain further what is "wrong" with the stock and MANY aftermarket speakers...
    If we look at sound as a visual graph,. laid out like a "graphic" equalizer,. a "perfect" response would be all frequencies,. at the same amplitude...
    A visual graph shows it with a perfectly flat amplitude across the screen,. ( we use the term "flat frequency response to describe the perfect sound,. it does not mean "flat" as in bland in this case)
    Perfect response:
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8
    20hz ---------1Khz -----------20Khz
    Bass - MidBass - Midrange - Treble - High Treble
    Most low end systems can't recreate either the higher frequencies ( the columns closest to the right hand side) or the extreme low frequencies, ( the left hand columns)We've actually grown extremely accustomed to ignoring the highest frequencies in all but the best sound systems,.
    ....But we all seem to crave some form of bass.
    Well you CAN'T get real base with small speakers and tiny magnets,. but you can force these parts to make lots of mid base,.. and cut off the high frequencies,.. two effects that can fool one into hearing "warm and bassy" sound.
    And so the technique so often employed is to design these speakers to really punch up the mid base, to "compensate" for the real low frequencies they can not recreate.
    This sounds like mud to the trained ear,. add to that the total lack of high frequency and it's a muddy, tubby warm bowl of soupy mush.. no crisp clean highs, and zero punch or feel to the bass.
    These speakers response would be far from flat,. we'd totally lose the extreme low and high end and see a big boost in the mod base around 125-500 hz... then a sever drop to the extreme left and right at the low bass, between 20-75 hz,. and at the high frequencies dropping after 5khz...
    0 0 0 8 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    0 0 0 8 8 8 8 8 8 8 8 8 8 0 0 0 0 0 0
    0 0 8 8 8 8 8 8 8 8 8 8 8 8 8 0 0 0 0
    0 0 8 8 8 8 8 8 8 8 8 8 8 8 8 8 0 0 0
    Lastly, FYI, the stock "Tweeter" is not a tweeter at all as far as any one with any real knowledge of speaker construction is concerned. The "tweeter" is in fact just another (albeit small) paper cone!!!
    It's a very very small WOOFER!
    Paper cones do NOT come close to reproducing the real high frequencies. If I were to guess,. we drop right off the charts at little more than 5Khz!!!!
