How do you remove 3rd gen door panel?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma_Jake, Feb 4, 2016.
  1. Feb 4, 2016 at 4:53 AM
    Tacoma_Jake
    Tacoma_Jake [OP] Well-Known Member
    2016 Tacoma TRD OR DCSB
    I wanted to ask some input from those in the know before I screw around and break something.
    I want to remove my front passenger side door panel. Sounds like I have something loose in there or something that needs to be tightened down. It vibrating like hell on the highway at 60 mph speed/revs.
    Need to get inside and take a peak.
    Do I need any special tools to do this??
  2. Feb 4, 2016 at 6:23 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Have you tried the glove compartment shelf?
  3. Feb 4, 2016 at 7:30 AM
    Tacoma_Jake
    For my rattle/vibration noise? Yea I had it removed a while ago. It's not the culprit.
  4. Feb 4, 2016 at 12:17 PM
    neegra
    neegra Well-Known Member
    GA
    2016 DCSBTRDOR4x4
    Sorry I didn't take off the door panel, but I had a little rattle in the switch panel on the driver's door and bass mekanik helped me find where the noise was originating :thumbsup:. There is a youtube video than runs from 10Hz-100Hz in 1Hz increments. Find the frequencies that excite it, and play it while you dampen and push on things. Good luck
    Here it is: https://www.youtube.com/watch?v=SV4ohgc6YJI
  5. Feb 4, 2016 at 12:40 PM
    Tacoma_Jake
    How did you remove/dampen the rattle with out removing the panel on the door??
  6. Feb 4, 2016 at 1:56 PM
    Tacoma_Jake
    After playing with the passenger window button I think your 100% right neegra!
  7. Feb 4, 2016 at 6:53 PM
    Judicar
    Judicar Well-Known Member
    Funny this post was posted today as this morning I noticed a vibrating on my passenger side.
  8. Feb 5, 2016 at 8:47 AM
    neegra
    GA
    2016 DCSBTRDOR4x4
    Glad you tracked it down. Now the harder part is making it stop.
    I didn't take it apart myself because when I took it in for the 5k service, I took the tech for a ride for another issue. I had a chat with him and told him I realize how much of a pain in the ass it is to track down/resolve and whatnot, and that I would really appreciate it if he could take a look so I don't break any tabs. He hooked it up... took the switch plate off on the drivers side and put some felt/vibration damper under it so it fits tighter. So far so good shrug_d9522f35eaca84c4ea2a46f1d684b2bc671972b8.gif
