How do you remove a sensor on clothing?
Discussion in 'Off-Topic Discussion' started by BigBawlzTaco, Oct 17, 2010.
  1. Oct 17, 2010 at 2:42 PM
    BigBawlzTaco
    BigBawlzTaco [OP] Well-Known Member
    2019 Toyota Tacoma SR
    My mom bought me a jacket from polo. By ALL MEANS IT WAS NOT STOLEN. They simply forgot to take that one sensor thing off that is the shape of a rectangle. I need a jacket tomorrow badly for it's gonna be freezing in the morning. My other jacket is covered in blood(Dont ask.) and I can't wash it when my mom's around or she will flip her shit. If you try to take this sensor off by yourself, is there ink inside it that would spill out onto the jacket?
  2. Oct 17, 2010 at 2:45 PM
    HomerTaco
    HomerTaco TOYWERX Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    :worthless:
    Seriously there are a ton of different designs of those sensors... take a pic. I've been in the retail environment for many years & can probably tell you how if I can see it...;)
  3. Oct 17, 2010 at 2:46 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    rubberband... keep wrapping it around sensor until it pops off
  4. Oct 17, 2010 at 2:50 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    screw driver or some pliers. what did ya steal?
  5. Oct 17, 2010 at 2:52 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    :spy:
  6. Oct 17, 2010 at 2:52 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    a lot of them jsut use a magnent to pull the locking mechanism out of the way.....so i'd try to find the strongest magnent you can and go from there. after that, it may be time for tools. if you have a steady hand, maybe dremel the steel pin going through the shirt?
  7. Oct 17, 2010 at 2:53 PM
    BigBawlzTaco
    this doohickey
  8. Oct 17, 2010 at 2:54 PM
    joey34mx
    joey34mx Well-Known Member
    Joey
    Southern California
    2005 Tacoma V6 prerunner
    hahah i really hope you dont plan on doing this operation in a store.
    can you say :spy::fenforcer:
  9. Oct 17, 2010 at 2:56 PM
    BigBawlzTaco
    I don't want to drive all the way to dawsonville to take it off and plus it's gonna be cold as tits tomorrow morning.
  10. Oct 17, 2010 at 3:00 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    the sensor pictured doesnt have the ink in it you can tug the hell outta the button end and it might come up a lil to where ya can get a pair of diagonal cutters in between the two pieces and cut it. its not easy trust me. we had to cut thru one at work once. but it worked
  11. Oct 17, 2010 at 3:00 PM
    HomerTaco
    Craig
    Bucks County Pa.
    That is a standard "Sensormatic" tag.
    With a nice pair of wire snips you should be able to cut it right off...
    The tool to remove these tags looks like a staple gun. It has 2 magnets that release the pin...
  12. Oct 17, 2010 at 3:01 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2010 Double cab 4X4 TRD Sport with JBL
    Redline Tuning hood struts, tinted windows, FX-R HID projector retrofit headlights, AMP power steps
    Did someone say cold tits?
    :worthless:
  13. Oct 17, 2010 at 3:06 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I've cut a couple of those off before. Just cut the plastic down around the steel pin enough to get some wire cutters in there and cut the pin. I think they have ink in them, not sure. So far I havn't caused any ink to come out.
  14. Oct 17, 2010 at 3:06 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Oh yeah, and this ^^!!:D
  15. Oct 17, 2010 at 3:15 PM
    BigBawlzTaco
    I've been using pliers. I bent the hell outta the circle thing on the other side but thats about it. I dont have wire cutters.
  16. Oct 17, 2010 at 3:25 PM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    If you are under the impression that tits are cold, maybe a jacket to wear shouldn't be your biggest priority right now.
  17. Oct 17, 2010 at 3:29 PM
    meeestirg
    meeestirg Well-Known Member
    D15, CA
    very strong magnet or find a friend who works in clothing retail. i only have the magnets and 3 prong key for liquor locks.
  18. Oct 18, 2010 at 7:53 PM
    Buzzoff
    Buzzoff Don't go ninja'in nobody don't need ninja'in
    The Nickel/5th Ward
    09 Tacoma DC TRD Speedway Blue
    Blacked out windows, 5100's@1.75", KMC XD Hoss795 16x8
    I've ran search warrants and seen where crooks put the ones with ink in them in the freezer. I guess the thinking behind this is to freeze the ink and then break it off. Not sure of it works
  19. Oct 18, 2010 at 8:08 PM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    Is it off?
  20. Oct 18, 2010 at 8:49 PM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    good idea.
