How do you remove an ECU wire?
Discussion in 'Technical Chat' started by rsmith99, Nov 8, 2014.
  1. Nov 8, 2014 at 4:35 PM
    rsmith99
    rsmith99 [OP] Member
    Ron
    Edmond
    none
    I am trying to install an alarm in my 2014 Tacoma. The alarm is from Toyota.
    There is one step where you must remove a wire from a connector and replace it with a wire from the alarm.
    I have a very small jewelers screwdriver, but I have tried for two hours and still cant get the old wire out.
    Can anybody tell me the trick?
    Thanks!
    Ron
  2. Nov 18, 2014 at 11:17 PM
    BCTSR5
    BCTSR5 NorthernTacoShop.com
    Vancouver
    2020 Taco TRD Sport
    there is a long rectangular part on the connector. pop it up carefully. it only pops up a couple mils. then look for a small tang holding the connector pin in. push it down and jiggle the wire until it pulls out. do not force the wire. to push the tang down, i usually use a unfolded paperclip or grind down a unfolded small cotter pin.
    hope this helps.
