how do you remove maintenance light?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SupremeDeluxe, May 23, 2012.
  1. May 23, 2012 at 6:42 PM
    SupremeDeluxe
    SupremeDeluxe [OP] Member
    Virginia
    Coma
    Hello everyone,
    My "maintenance required" light came on in my truck. It is a 05 Tacoma Prerunner SR5 that is a 2.4L 5 speed manual. I tried unhooking the battery but it is still there and can't seem to get rid of it. Any suggestions?
  2. May 23, 2012 at 6:43 PM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
  3. May 23, 2012 at 6:45 PM
    dpalmer619
    dpalmer619 Well-Known Member
    Derek
    San Diego
    '07 White TRD sport doublecab
    Icon 2.5 coilovers
  4. May 23, 2012 at 6:47 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
  5. May 23, 2012 at 7:13 PM
    myname150
    myname150 Well-Known Member
    1.) Turn the truck off and take the key out
    2.) Push and hold the button for the odometer with one hand
    3.) Put the key into the ignition with your other hand and turn the key to the "ON" position...do not start your truck.
    4.) You'll see something like this: "--------" show up on the odometer read out.
    5.) Wait for all the dashes go away and then shut off the truck.
    6.) If you want, start your truck and it should no longer be there. The Maintenance Required light has now been reset for another 5,000 miles from your current odometer readout.
  6. May 26, 2012 at 4:22 PM
    monti
    monti Member
    Pittsburgh
    none yet...
    Thanks!!
  7. May 27, 2012 at 8:19 PM
    SupremeDeluxe
    Virginia
    Coma
    thanks everyone. i was able to turn the light off.
  8. May 27, 2012 at 8:22 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Hopefully you did this after changing your oil. That's what the light is there to remind you to do.
