how do you remove plasti dip?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by josepenajr, Aug 16, 2013.
  1. Aug 16, 2013 at 1:46 PM
    josepenajr
    josepenajr [OP] Well-Known Member
    Laredo , Texas
    13 Texas Edition Double Cab
    3 inch lift, Painted black rims, black bull bar, black bug deflector, Black PlasTi Dipped Emblems, 275/70/17 Tires
    how do you remove plasti dip? i know you can just peel it off but is there a fast way to get the smaller hard to reach areas?
  2. Aug 16, 2013 at 1:49 PM
    TailDrag
    TailDrag Well-Known Member
    Spray with WD40. Pressure wash or blast with hose.
  3. Aug 16, 2013 at 1:49 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i have not found a way. but also have not really tried any other ways.
  4. Aug 16, 2013 at 1:49 PM
    josepenajr
    Laredo , Texas
    how long do i let the wd40 sit before i hose it down ?
  5. Aug 16, 2013 at 1:50 PM
    TailDrag
    Dunno. Soak it good and try after a minute or 2. Rub with your finger and see if it is loosening up. If it is, spray away.
  6. Aug 16, 2013 at 1:52 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Use goo gone. Don't drench it, but just wet it (spray bottle type works best here). Let it sit for a little bit and then just wipe it off. Super easy
  7. Aug 16, 2013 at 1:56 PM
    josepenajr
    Laredo , Texas
  8. Aug 16, 2013 at 2:20 PM
    06hawkman
    06hawkman Active Member
    Tony
    salt lake city
    08 Tacoma OR
    custom exhaust
    claybar and quick detailer works really well
  9. Aug 16, 2013 at 2:30 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Lol
  10. Aug 16, 2013 at 4:04 PM
    memario1214
    Colton
    Missoula, MT
    If you put it on too thin... its difficult to remove.
  11. Aug 16, 2013 at 4:04 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    If you have one or two very thin layers, it's really hard. I had found this out last week. Thick layers are the best and the easiest to get off whatever it is your dipping. So watch that overspray.
  12. Aug 16, 2013 at 4:24 PM
    josepenajr
    Laredo , Texas
  13. Aug 16, 2013 at 4:34 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    My fingers were sooo damn raw when I peeled it off all my wheels. I got it on too thin. Degreaser helps too, but make sure you dont use that anywhere you care about the finish underneath.
  14. Aug 16, 2013 at 4:37 PM
    ConnorBryan
    ConnorBryan New Member
    06 TRD prerunner
    Car wax takes it off too. Waxed mine and unintentionally re chromed my emblems haha.
  15. Aug 16, 2013 at 4:46 PM
    josepenajr
    Laredo , Texas
    lol it happens lol
  16. Aug 16, 2013 at 5:16 PM
    jw1983
    Alberta
    Saves you from waxing later.
