How do you remove spare tire?
Discussion in 'Wheels & Tires' started by LazyRyan, Nov 1, 2008.
  1. Sep 3, 2009 at 2:25 PM
    cornwall325
    cornwall325 Toyota newbie...
    Jonathan
    Virginia
    09' D.C. TRD Sport 4x4
    Seatbelt chime turned off, Toyota bedmat, Wet Okoles, stock other than that.
    I was wondering if the spare tire lowering mechanism has a "stop" on it when you raise the spare back up? I lowered mine the other day just to check the pressure (1st time on my new truck) and when I initially raised it back up there was a click sound I heard. I lowered it back down just a tad and then raised it back up but didn't get a click sound. I'm wondering if this just happened because everything was new or whether I should have raised it up a little more? It's not flopping around by any means under there but it does have a wee little bit of movement to it. Anyone got any input on this? I didn't want to crank down on it too much with the fear of not knowing much about the mechanism itself and possibly stripping something.
    thanks
  2. Sep 3, 2009 at 2:34 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    Just turn it till its tight enough that it dont move around, there is nothing that tells you when it is tight enough (ie click sound). I always go by the saying "tight is tight and too tight is broken"
  3. Sep 3, 2009 at 2:46 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    OK, this was going to be my next "mod invention"......I am actually quite shocked that NO ONE on TW has attacked this obvious mechanical mind F**K: the release mechanism for the spare tire is PURELY NEANDERTHAL. I think we need to have a CONTEST to see who can invent the best fix for this obvious mechanism that was invented by the Toyota Engineering Dept at their SAKE party......and I can assure you, SAKE leaves one helluva hangover headache (I know, because I love Sushi). OK, I am going to give everyone a HINT of my idea (yet to be created): The mechanism you attach the hook to needs to be brought out of the dark cave of the troglodytes and affixed to the external cave entrance. :) :) :)
    El Tano likes this.
  4. Sep 3, 2009 at 3:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Kinda like this?
  5. Sep 3, 2009 at 3:59 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Chris...dude....you're reading my mind....sort of.....the trick is to get the attachement for the socket where it is easily accessible....in these videos, someone had to @!*&#*@!& get the rod attached to the internal thingamajingee........which I will hereafter refer to as the SAKE WINCH.
  6. Sep 3, 2009 at 4:00 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    When you lowered your spare to "check the pressure", did you flip the tire over so you'll never have to do so much heavy lifting next time?
  7. Sep 3, 2009 at 4:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually, I have been working on a design that uses a starter motor (that attaches to the lowering/lifting mechanisim of the spare tire), with a push button in the driver side cubby (in the bed), so when its pushed, the tire lowers. Flip a switch, to reverse polarity, and push the button again, and the tire raises. I havent gotten to far, being as the drill works fine. In the vid, the battery was about dead. Maybe one day, when I have some spare change, I will finish my idea. :)
  8. Sep 3, 2009 at 4:11 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Ok, you can lower it with the drill, but will it raise it back up? :D
  9. Sep 3, 2009 at 4:12 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Cool! I don't mind cranking, but my goal is to eliminate the "searching in the dark" for the Sake Winch.:D
    Oh, by the way, go NCState!!!!
  10. Sep 3, 2009 at 4:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    yes it will. I raised it up, only to find the battery on the camera dead. After I gave it a quick charge, now the battery on th edrill is dead. Its charging now, but the charger is a 12 hour POS. :(
  11. Sep 3, 2009 at 4:15 PM
    ImpulseRed008
    Susan
    SC
    One reason not to depend on power tools :D
  12. Sep 3, 2009 at 4:16 PM
    TicTacOma
    Columbia,SC
    Just get an old Toupee and cut a hole in it.....
  13. Sep 3, 2009 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And that being said, would be when you use the OEM hand crank. :p
  14. Sep 3, 2009 at 4:18 PM
    ImpulseRed008
    Susan
    SC
    Exactly :p :D
  15. Sep 4, 2009 at 8:49 AM
    #35
    NuovoTech
    NuovoTech Well-Known Member
    Upper Left Corner
    09 Tacoma 4x2
    Putting tire valve facing down makes sense, wonder why manual states the opposite? Anyone found a downside to doing that way(pointing down)? :confused:
  16. Sep 4, 2009 at 8:59 AM
    #36
    ImpulseRed008
    Susan
    SC
    I'm thinking that it would protect the valve from getting damaged/broken if you run something over, that gets kicked up under the truck... Plus the tire sits lower when upside down, so closer to potential damage :confused:
    Just my .02
  17. Sep 4, 2009 at 8:59 AM
    #37
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bingo!
  18. Sep 4, 2009 at 9:14 AM
    #38
    NuovoTech
    Upper Left Corner
    09 Tacoma 4x2
    So then, do most folks here leave the valve pointing up or down? ;)
  19. Sep 4, 2009 at 9:16 AM
    #39
    ImpulseRed008
    Susan
    SC
    Down so you can get to it :eek:
  20. Sep 4, 2009 at 9:30 AM
    #40
    r12rex
    r12rex Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    Would a 32" tire fit under there? I want a matching spare tire for the truck, but am not sure if a tire that large would fit underneath? Anyone?
    Kind regards,
