How do you remove spare tire?
Discussion in 'Wheels & Tires' started by LazyRyan, Nov 1, 2008.
  1. Sep 4, 2009 at 9:31 AM
    #41
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It will fit, but you may have to remove a couple of tabs
  2. Sep 4, 2009 at 10:49 AM
    #42
    r12rex
    r12rex Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    Thanks Chris!
  3. Sep 4, 2009 at 6:30 PM
    #43
    cornwall325
    cornwall325 Toyota newbie...
    Jonathan
    Virginia
    09' D.C. TRD Sport 4x4
    Seatbelt chime turned off, Toyota bedmat, Wet Okoles, stock other than that.
    Unfortunately I didn't flip mine over like some on here have. I didn't do this just because I know I won't be fooling with it that often since it doesn't have a sensor in it. Also I just prefer the way the tire sits with the valve stem pointing up, but that's just me.
  4. Sep 4, 2009 at 8:07 PM
    #44
    NuovoTech
    NuovoTech Well-Known Member
    Upper Left Corner
    09 Tacoma 4x2
    I went to look at mine & decided to leave it pointed up, but I rotated the tire till the valve was closest to my license plate. Then I still can check & fill up the tire easily. Gotta get down on the ground either way... :D
  5. Sep 4, 2009 at 8:36 PM
    #45
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If keeping an eye on the pressure is the main concern, Use one of these:
  6. Sep 4, 2009 at 8:39 PM
    #46
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    RV RUBBER TIRE VALVE STEM EXTENDERS
    Constructed of high quality two ply rubber tubing reinforced with a tough nylon braid.
    1-PACK 13 " STRAIGHT EXTENDERS
    PART # 02052
    $ 13.99
  7. Sep 4, 2009 at 8:39 PM
    #47
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just about any RV store will carry these. :)
  8. Sep 7, 2009 at 5:08 PM
    #48
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
  9. Sep 7, 2009 at 5:37 PM
    #49
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  10. Oct 25, 2009 at 4:41 PM
    #50
    JKD
    JKD Well-Known Member
    I searched before asking the same question (thus finding this thread). The 2009 owner's manual says to crank the spare up and keep going until you hear three "clicks". Well, I didn't hear or feel anything that I would describe as a "click", but it did feel like I reached the end of travel and cranking the handle would "override" the crank mechanism. So I cranked it three times (thus overriding the mechanism three times) and figured that's a "click".
    It makes me a little nervous, though. That compresses the spring completely, which makes me wonder if this procedure over-tightens the spare. I'm really not interested in seeing my spare skidding down the highway behind me.
  11. Oct 25, 2009 at 5:05 PM
    #51
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 Tundra TRD OR, 05 GX470
    tacoma sold 11/13/13 GX470 has 2” Dobinsons IMS w/JBA UCA, Baja Designs S1 ditch lights, more to come!
  12. Nov 13, 2009 at 10:54 AM
    #52
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    Tire is facing up for a few reasons:
    A) keeps the outward side of the spare away from direct road debris, to keep the exterior face looking better when being used on the truck
    B) the tire lifts more level due to the balance point or center of gravity on the tire. If you have it with the valve facing down, it will not lift flat and might not sit against the underside of the frame properly
    C) to make it a pain in the anus to check/adjust tire pressure.
    The tire retainer mechanism has a clutch in it. The 'clicks' may not be audible, but you should feel it. It's just the point where the clutch engages and slips. That spring is going to be fully compressed so the tire doesn't bounce around, a spring that size probably only takes a few hundred pounds to compress fully.
  13. Nov 13, 2009 at 11:08 AM
    #53
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I have not found (B) above to be the case.
  14. Nov 13, 2009 at 11:13 AM
    #54
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    This thread reminds me to go get the spare tire lock. Better than nothing I suppose.........I'd be concerned about puttin any bigger tire under there & having to trust that skinny cable. This is a carryover part from my 82 prerunner. The spare mounted the same way, XCEPT, it had a nice chain instead of a cable of seemingly questionable capabilities.
  15. Nov 13, 2009 at 12:16 PM
    #55
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    As far as a lock for the spare, I just used some heavy cable and had loops swaged on both ends, then ran one end up through the wheel and over the frame and used a master lock the secure the ends together. I figure if the cable ever breaks on the lowering mechanism, the cable lock would keep the tire from flying down the road.
    An idea to make lowering the spare easier would be to have a rod welded to the lowering mechanism and long enough to sit flush with the bumper hole with a fitting on the end to attach the crank handle or a drill motor with an extension. The rod could go through a rubber grommet in the bumper hole to help keep it in place and not bounce around.
  16. Nov 13, 2009 at 2:53 PM
    #56
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :annoyed: They failed on that one... there are wear marks from where the tire meets the frame under the truck. There's a thread around here somewhere, where someone posted pics of his/her spare with the marks. I have the wear marks on my spare.
  17. Nov 13, 2009 at 3:57 PM
    #57
    JKD
    FYI, Toyota answered my question, and tried it out--they said the manual will be changed, that there are no clicks.
  18. Nov 20, 2012 at 1:57 PM
    #58
    sileliasdan
    sileliasdan New Member
    It's going to rust!
  19. Nov 20, 2012 at 2:01 PM
    #59
    sileliasdan
    I had to increase the air pressure on my spare today due to the sensor going on. The stem as positioned was very accessible. It was pointing directly towards the rear of the truck. I was able to insert my PSI tester and double check the pressure - it was super low!
    Drove to the gas station and was able to easily insert the hose thru one of the openings of the rim and inflate the tire.
    I did look at lowering the tire first but that looked too darn complicated!!
  20. Nov 20, 2012 at 2:02 PM
    #60
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I am still thinking about the cure for this debacle by Toyota. I WILL find a sublime anwer to this. No, it will not rust. I use 100% high grade stainless steel in everything I do that involves metal. Do it....Do it right.
