how do you remove the interior scuff panels?
Discussion in 'Audio & Video' started by Silentknight11b, Apr 13, 2011.
  1. Apr 13, 2011 at 6:45 AM
    Silentknight11b
    Silentknight11b [OP] Member
    SC
    2011 Doublecab TRD Sport 4x2
    TRD exhaust, PIAA bulbs, AFE drop in, N-FAB stepbars, more to come.....
    I am abuot to start running power wire from the battery to behind the rear seats in a 2011 double cab. How do you remove the interior scuff panels (inside the front and rear doors where your feet may hit enterring or exiting the vehicle)? I am sutre is something simple like "It's just friction clips, give it a yank up, in, etc..." But I want to make sure before I go snatching panels and breakign something. Thanks for the help!
  2. Apr 13, 2011 at 6:53 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Just pull, only held in by clips
  3. Apr 13, 2011 at 8:35 AM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    ^^What he said. For the fronts make sure you remove the kick panels first.
  4. Apr 13, 2011 at 8:55 AM
    52419 Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    is this a first gen or second? cause i know the first gens are just screws and clips.
  5. Apr 13, 2011 at 1:52 PM
    Silentknight11b
    SC
    It's a 2nd gen- 2011. To remove the kickpanles- just friction clips also- pull?
  6. Apr 13, 2011 at 1:54 PM
    macgyver
    Brad
    Canton, GA
    You got it
  7. Apr 13, 2011 at 2:18 PM
    478DblSport
    Byron, GA
    My apologies, the kick panels aren't removed before the sill plates but removing them will help with fishing wire. The passenger kick panel has a knob thingy that unscrews then the panel pulls off. The driver side is much the same but there's a foot rest that pulls off first.
