How do you remove the "Tacoma" & Toyota logo?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jbclarke16, Jan 12, 2012.
  1. Jan 12, 2012 at 9:23 PM
    jbclarke16
    jbclarke16 [OP] Well-Known Member
    Josh
    Moncks Corner, South Carolina
    06 Silver DCSB
    Double Din touch screen radio, and one 10" Kicker Sub
    I want to paint every face plate or lettering on my truck from chrome to black, how do I get them off? Do i just pop them off? Or what? I probably sound like an idiot but ohwell.
    Also, does anyone know where I may be able to find another Toyota logo for my front grille that isn't so...plain? Sort of like the Devil Logo, or any other kind.
  2. Jan 12, 2012 at 10:33 PM
    PVT Pablo
    PVT Pablo Ultra Junior Member
    Paul
    Chesapeake, VA
    2016 4Runner TRD Pro
    The Search Function is your friend.
    I used the fishing line technique. Warm up the emblem with a hair drier, pull a fishing line through the glue between the paint and emblem. Then clean off the excess glue with a paint safe adhesive remover. Its a good idea to wax over the area where the adhesive remover touched.
  3. Jan 12, 2012 at 10:34 PM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Niceville, Florida
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    All the badges on the sides and rear can be removed with fishing line. I used like 30# test and it worked well. Just wrap it around your hands and then slide it between the truck and the badge and make a sawing motion while pulling it from one side to the other. Might want to wear gloves though. Then you can roll whatever is left of the tape off the truck. If Theres a residue use some goo gone or other adhesive remover. Then remove the tape from the badges, paint em, apply new tape, and stick em back on. You might want to mark the location of the badges before removal though. Make a tight box outline around them with masking tape or something similar if you plan on putting them back on in the same place. Front emblem is held on by three or four tabs. Press in on them from behind the grille and it comes right out.
    As for the different emblem search for devil horns or metalmiller can probably make you something.
  4. Jan 12, 2012 at 10:34 PM
    Manwithoutaplan
    ID
    agree
  5. Jan 12, 2012 at 10:35 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    From a vendor on here that had a group buy.
  6. Jan 12, 2012 at 10:37 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    heat gun and fishing wire.
  7. Jan 13, 2012 at 9:13 AM
    jbclarke16
    Josh
    06 Silver DCSB
    I gotcha, thanks a lot! But for when i reapply them to my truck what in your opinion would be the best adhesive so, they don't come flying off driving down the road? haha
  8. Jan 13, 2012 at 9:25 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Bull bar, nerf bars, bed extender, tonneu cover, bug deflector, wish list,....
    3M double sided tape. Your autoparts store should have some that are spcificaly for automotive use, i.e. outdoor use. You will have to cut narrow strips or stick it to the back of the emblem and cut it out with an exacto knife.
  9. Jan 13, 2012 at 9:28 AM
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    If you don't have any fishing line you can also use dental floss.
    WD-40, Goo-Gone, "3-in-One oil," rubbing alcohol are all good for removing any adhesive residue.
    Ray
  10. Jan 13, 2012 at 9:28 AM
    jbclarke16
    Josh
    06 Silver DCSB
    Thanks man! I appreciate your help!
  11. Jan 13, 2012 at 9:33 AM
    bizjettech
    bizjettech Well-Known Member
    San Antonio, TX
    2013 MGM DCSB 4x4 TRD OR
    undercover flex bed cover
    Guess I'm the only one that did not use fish line. I just used an industrial heat gun and pry'd up on one corner with my finger and peeled them off. Rubbed off the remaining tape with my fingers and then used adhesive remover.
  12. Jan 13, 2012 at 10:10 AM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
  13. Jan 13, 2012 at 3:13 PM
    jdm.obp
    jdm.obp Well-Known Member
    561, FL
    3" Pro Comp, 5% all around, Antenna X shorty, Debadged
    I say leave them on and use plasti-dip. Just tape off a small area around each emblem and paint away, then peel the overspray off and done.
  14. Jan 13, 2012 at 3:15 PM
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Madison, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
  15. Jan 13, 2012 at 3:16 PM
    MXscott14
    MXscott14 Bartle Do Member
    Keith Stone
    In Front Of You
    2006 2nd generation antique
    Black Headlight, Foglight always on,
    use a ball point hammer (ball end) and should come right off
  16. Jan 13, 2012 at 3:22 PM
    Ohbrian
    Ohbrian Taco Roja
    Brian
    Fremont, CA
    04 PreRunner
    Eclipse head unit,scratched paint,ripped seat, black chaos 6 rims, Bilstein 5100's, top plate spacers, AAL, Midget antenna, Bakflip G2 cover, 14" Magnaflow, 400W inverter, LR UCA's
    I went to the hardware store and got a plastic putty knife. Takes those things right off without screwing around with fishing line.
  17. Jan 13, 2012 at 9:37 PM
    ROGU3 PR3DATOR
    Jake
    Niceville, Florida
    I think the idea behind the fishing line is that it is basically impossible to damage the paint that way. Versus a plastic putty knife that could slip. I have no doubts that it would work, just a touch more risky.
  18. Jan 14, 2012 at 4:07 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Hair dryer and fishing line
  19. Aug 7, 2012 at 7:23 PM
    PhantomVirus
    PhantomVirus Well-Known Member
    Ron
    People's Republic of NJ
    2012 Super White TRD OffRoad Double Cab
    Don't steal my tailgate Mod, Hardwired Valentine1 Radar Detector, Smitty N-FAB Nerf Bars, Led lights (Maps, overhead & rear License Plate), Debadged, TRD rim center covers, Replaced Chrome Grill with OEM Super White, PlastiDipped Toyota Logo on Grill BLACK, Distinct Offroad Custom light bar
    If you do it in the summer you can skip the hair dryer. I just did mine last weekend and it was 90 degrees & humid as hell in NJ.
    AFTER painted Black / Rebadged:
