How do you.........remove window tint
Discussion in 'Detailing' started by coffeesnob, Mar 23, 2011.
  1. Mar 23, 2011 at 2:40 PM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Thanks to Virginia law:mad: my window tint will not pass inspection for safety sticker so..................what is the preferred way to remove the tint. What have you all used? Thanks
  2. Mar 23, 2011 at 2:42 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    go to a differnt insp shop......
  3. Mar 23, 2011 at 2:42 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    a window cleaner with amonia? :notsure:
  4. Mar 23, 2011 at 2:43 PM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    A warm day is best. Pick a corner and peal. Then use a razor blade and soap/water squirt to scrap all the glue off. DONE!
  5. Mar 23, 2011 at 2:45 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    or just bash the windows out ny stylz :rolleyes:
  6. Mar 23, 2011 at 2:46 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, Nitto Mud Grapplers, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5%/30% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    Its a bitch to do
  7. Mar 23, 2011 at 2:46 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    try this guys idea
  8. Mar 23, 2011 at 2:51 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    dam in ny your window could be shattered and your seat belts cut out n no one would give a flying f^&k...............
  9. Mar 23, 2011 at 2:52 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    & a heat gun
  10. Mar 23, 2011 at 2:57 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    If he uses those he will end up cutting himself ..
    I used steam a a square razor blade
  11. Mar 23, 2011 at 2:58 PM
    VanillaGorilla
    VanillaGorilla Itsnevertoearlytostartbee fingupyourobituary
    Erik
    East Bay Area, CA
    09 BSP Pre Runner SR5
    Tint. (DONE) Soon to come. 3in Llift (OME) Color matched grill (DONE) BHLM (DONE) Tail tint (DONE) Pro comp rims (8069) End goal: Murdered out truck
    flamethrower........I was going to say steam also, I've heard it works alright but either way it will be a PITA, I'd recommend a glass scraper as a necessity but thats my opinion
  12. Mar 25, 2011 at 6:41 AM
    coffeesnob
    VA
    ended up paying a glass shop to get it off. I took the passenger side film off ok but it left the glue on and I could tell this is just not gonna be worth the aggravation, I don't know how they did it but man it was a perfect clean job and quick. I would been several hours on one window and would have not got it that clean.
  13. Mar 25, 2011 at 7:11 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    New razor blades (square), goo gone, and windex, lots of paper towels.
    Cut it into a few sections first (6 should suffice.) Then start at a corner and peel. Then take the goo gone to wipe off any adhesive residue, use it liberally because it will begin to smear as the solvent dries. Then once you think you've got all the adhesive off. Spray the window down with windex and use the razor blade at about a 45 degree angle to scrape the window down to be sure you get everything off the glass working in small sections. Then wipe it down with windex one more time and you should be done.
  14. Mar 27, 2011 at 12:43 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    OCEANSIDE, CA
    2016 DBL CAB 4x4TRD OFF ROAD
    6 inch Pro comp Stage 1 lift 305/70/18 MasterCraft MXT 18x9 Monster wheels,
    Home deopot sells some stuff called goof off and it will take that glue right off i had to do it in utah too.. it still sucks
  15. Mar 27, 2011 at 12:48 PM
    Sprink669
    Sprink669 Well-Known Member
    when i lived in Vegas the shop that I went to had to redo my back window of a Grand Cherokee and they put a black trash bag on the outside of the window and sat the vehicle in the direct sun for about a half hour and the tint peeled right off and there was virtually no glue left on the window. The temps were in the high 80's when this was done.
  16. Apr 2, 2011 at 8:55 AM
    07navajoTACO
    07navajoTACO Well-Known Member
    Tennessee
    07 PreRunner
    De-Flapped, De-badged. Sockmonkey decals installed.
    There are some ideas on window tint removal on youtube. I personally used a heat gun with a razor to scrape off the glue residue off. And it worked like a charm. I removed the front door windows of my wife's Intrepid. And that took just 20 minutes for both.
  17. May 23, 2011 at 8:35 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    Took off my front window tint. Too dark and cop stopped me and warned me that it was too dark read 28 on his sensor tool, should be 70. Oh well, the back is still legal and dark.
    I used garment steamer. Both sides peeled off in one piece. Very little glue left and that cam off with goo gone, razor and Windex and paper towels.
  18. May 23, 2011 at 9:04 PM
    LTE
    LTE NRA Benefactor Member
    in my own little world
    07 SR5II; Longbed; FLyzeyes LED
    window tint, step bars, Flyzeye LED interior console light
    With the handist dandist tool ever!
    It's not a slicer, it's not a dicer. It's not a hooper in a chooper!
    Sledge-o-matic!
    Removes tint from windows. Or Windows from tint.
  19. May 23, 2011 at 9:08 PM
    devilstonic
    devilstonic Well-Known Member
    Leah
    Denver, CO
    TRD 4x4 Offroad
    You could do as the thieving bastard did to my tinted window and take a crow bar to it. ;)
  20. May 24, 2011 at 1:10 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
