How do you repair glass and shocks on a shell?
Discussion in 'Tonneau Covers, Caps and Shells' started by Mountain_Goat, Nov 23, 2016.
  1. Nov 23, 2016 at 6:01 AM
    Mountain_Goat
    Mountain_Goat [OP] Well-Known Member
    2001 4WD DC SB TRD OFF ROAD
    Looking at a used LEER shell. Right side glass and shocks need replacement. No luck so far finding the glass. How much does it cost to get the replacement glass and fix the shocks?
    Photo is before glass was broken. trying to figure out how much I can spend on the shell after repair costs...1st gen dc sb...
    Thanks everyone,
    Chris in the Mountains
  2. Nov 23, 2016 at 6:03 AM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    :redxfall: picture is not working
    But my shocks were about 20 bucks to replace from ebay and my back window glass was $350. I'd say the side window may be around $200
  3. Nov 23, 2016 at 6:14 AM
    Mountain_Goat
    Image should work now . any suggestions on where to get the glass? was that an installed price or part cost?
  4. Nov 23, 2016 at 6:24 AM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    I had to have my back glass replaced at a shop , since it is a frameless back glass they had to measure it and send the info to the factory Century (ARE) took about 2 weeks to get it . The shocks are easily replaceable locally or online just look at the information on the shock and find the appropriate weight lift and length and done. When my back glass broke I fabricated an alum one (See Album) till I got the new glass you can probably do the same thing . I will say this the back glass on a double cab with rear camera I really can't see much through the dog crate etc back there so having it solid alum did not matter to me at all. You could get away with making your side cap windows solid probably and save money especially if you wheel. Just a thought. I also found out when my back glass shattered that my glass coverage from state farm paid for a new one only cost me 50 bucks, I was sweating the cost as originally quoted $540.00 for a new window which is 1/3 the cost of a new cap!!
    Cypher
  5. Nov 23, 2016 at 6:28 AM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Mine was $350 installed. I got mine from a local leer dealer as you cannot order the glass online (at least for the back window). If you have a local leer dealer I'd go over there and get a quote
  6. Nov 23, 2016 at 11:22 AM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    That's a leer 100xq. I hear those side glass replacements are expensive! Check with your local leer canopy dealer.
  7. Nov 23, 2016 at 1:49 PM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Almost any NAPA, PepBoys, Kragen, AutoZone or whatever you have in your town stocks the shocks (really gas springs) and they're cheap.
