How do you Replace the Rear Glass slider on an 08 Tacoma?
Discussion in 'Technical Chat' started by patrickockander, Dec 9, 2008.
  1. Dec 9, 2008 at 4:37 PM
    patrickockander
    patrickockander [OP] Say What?
    Patrick
    San Antonio, TX
    TACOMA TRD Offroad version 4x4
    Supercharged, Hood Lift-struts, Borlas, 2-tone Leather, Husky Liners, 16" Completely rewired audio system, Components front/rear, Dbl Limo Tint, 2-din JVC KWNX7000BT (DVD+GPS), TRD CAI, disabled seatbelt alarm, E3 Plugs, Halo Headlights, Tuck-in style Rain guards, dealer sticker removed, Step rail,
    I Just ordered a rear slider for my 08 Tacoma dbl cab and I'm not certain how to swap it out...anybody done it? Anybody know how?
  2. Dec 9, 2008 at 5:01 PM
    patrickockander
    Patrick
    San Antonio, TX
  3. Dec 9, 2008 at 5:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    at pepboys....they actually sell a ropecable type deal for installing windshields. you have to be careful with it, but i think it will work on rear glass too man. and it aint expensive either.
  4. Dec 9, 2008 at 5:03 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
  5. Dec 9, 2008 at 5:13 PM
    patrickockander
    Patrick
    San Antonio, TX
    HAHA...yeah, I even once saw a prom suit and dress made out of duct tape....
  6. Dec 9, 2008 at 5:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thats kinda cool.........dude almost looks like the tin man from the wizard of oz!!!:D
  7. Dec 9, 2008 at 5:19 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    I put one in my 87 single cab many years ago at my buddies Z-bart. Some are easy and others, not so easy. Mine, unfortunately was the ladder, but we got it in.
    No way it would have gone in without two of us.
  8. Dec 9, 2008 at 5:33 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Skip the WD-40 and use dish soap. The WD will get everywhere and is a bitch to clean up after. One guy inside and one guy outside and the rope will work. Run the rope around the gasket so each end of the ropes are/meet at the bottom center so you can pull from the bottom center to the lower outside corners at the same time and then work up the side and across the top. Keep wrapping the slack rope around your hand and keep an even pull while the outside guy keeps inward pressure.
    It'll be in before you know it.
    You may want to run a bead of sealer around the outside part of the gasket just for insurance. Get a plastic putty knife or what is called a "popsicle stick" It's a plastic stick that allows you to pry and "walk" the gasket out without scratching the truck. Pull that outer lip as far as you can, run a bead of sealer close to the slider frame , then let the lip snap back. If you set the bead deep enough you won't have to clean up any ooze.
