How do you shift your auto?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by verynearlypure, Mar 3, 2021.
  1. Mar 3, 2021 at 2:24 PM
    verynearlypure
    verynearlypure [OP] Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    :anonymous:Hello 2nd Gens :wave:
    Be warned, this is not a Friday thread!!!
    Not looking for any elitist remarks insisting we should have a manual. They don’t make a manual for southpaws anyway. Now excuse me while I risk Tacoma World humiliation.
    Onto the topic at hand...
    Looking for some input on how to correctly shift from 4 to overdrive as the manual only states specific ranges for gearing. I’m not looking to cause excessive wear in the transmission, if that’s even possible.
    Is it normal and okay to still be applying throttle when upshifting into overdrive? (D). Sometimes I get a rev hang or an obvious hesitation. Sometimes a slight jolt/thud which I could only assume in the TC. Even while on flat ground with no throttle applied it’s not a smooth and seamless as the other gears
    The dealer states throttle application is fine as long as it’s a conservative amount and on flat ground. They couldn’t give me an RPM figure but insisted as minimally as possible. Wouldn’t that defeat the purpose of an upshift if you have to slow down? I’m not cycling through the gears manually like a Jeff Gordon here. I’m usually coming out of heavy engine breaking and upshifting back to D.
    What’s everyone’s experience with this? I do moderate towing during the warm months here and the last thing I would want is a slipping transmission. I have never towed in OD. Bought from original owner with 13k miles reaching around 48k miles now. Never flushed tranny fluid.
    Any constructive input not consisting of “qUiT dRiViNg iT lIKe a MaNuAL!” is appreciated.
    Biscuits, Slashaar and BassAckwards like this.
  2. Mar 3, 2021 at 2:31 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I let the truck do the shifting. I just put the selector in "D" and go. Towing, the selector goes into "4" only.
    My left hand does the steering and blinkers. My right hand controls the radio, AC and wipers.
    BOSS-DS2, lynyrd3, Biscuits and 6 others like this.
  3. Mar 3, 2021 at 2:34 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Ill use 4th on steep grades cause it likes to take naps and wont down shift on its own unless i put my foot through the floor.
    Other than that she stays in D
    lynyrd3 and verynearlypure[OP] like this.
  4. Mar 3, 2021 at 2:35 PM
    verynearlypure
    Ernest
    The Buckeye State
    Thanks for the response but I’m not asking for body posture and positioning when towing. This is more of a technical question regarding throttle position procedure when upshifting from 4 -> Overdrive and whether or not doing it in certain areas of the powerband are doing any premature harm.
    What’s your experience when getting back into overdrive? Do you aim for an special RPM for a smoother transition? What’s the highest speed you’ve put back into OD?
    Do you ever get any hesitation, rev hang, or jolt/slap?
  5. Mar 3, 2021 at 2:39 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    There is no reason to be in 4 unless towing. For general driving put in D and be done with it. If your in 4 and want to go to D just do it, there is no set rpm point to do it.
  6. Mar 3, 2021 at 2:39 PM
    Knute
    Reality.....you don't need to do the shifting. The truck will handle it.
    Typically, when up shifting you relax the throttle, so the engine speed drops, make the shift, then apply throttle.
    But, none of this is needed with an Automatic
    lynyrd3 and TRDSport10 like this.
  7. Mar 3, 2021 at 2:40 PM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    sorry for my ignnorance, but 2nd gens have an overdrive?
    lynyrd3 likes this.
  8. Mar 3, 2021 at 2:42 PM
    verynearlypure
    Ernest
    The Buckeye State
    See that’s what I though too with modern automatics. So it shouldn’t matter if my foots into it or not when going back into overdrive for cruising without tow. I’ve tried shifting the truck without throttle like my manuals in the past but it seems to like the foot on the gas. Sometimes when I do this there is a hesitation/hang and sometimes an audible thud similar to 4WD system. My worry is too high of powerband could prematurely cause trans failure. I know nothing of transmissions.
    That’s not correct, there are plenty of other reasons. I don’t think you read the post but thank you sharing.
  9. Mar 3, 2021 at 2:43 PM
    Knute
    Can't speak for all 2nd Gens. I know my '06 with AT has overdrive.
    TRDSport10 and DarthPow[QUOTED] like this.
  10. Mar 3, 2021 at 2:45 PM
    Knute
    OP.......stick it in "D" and drive. Forget about trying to shift it like a manual.
    They are complete different beasts.
    lynyrd3 likes this.
  11. Mar 3, 2021 at 2:47 PM
    DarthPow
    I have a 12 TRD sport 4wd. how can I tell if I have overdrive? is there a button or indicator on the PRNDL if you have it?
  12. Mar 3, 2021 at 2:50 PM
    Knute
    Refer to your Owner's Manual. It will have details for your truck.
    FWIW, I'm pretty sure your Auto has OD.
  13. Mar 3, 2021 at 2:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I dive my truck in 4th all frequently. Probably 3x per week.
    There are certain roads I drive that the speed limit is right in between where the truck likes to shift in between 4th and 5th and it constantly want to lock/unlock the converter.
    So I drive it in 4th and cruse there at around 2000 rpm. (The same RPM I am turning in 5th at 70mph)
    When I shift to 5th from 4th. I let off the throttle and shift the selector to 5th.
    The truck changes gears, then I reapply the throttle.
    dk_crew, Biscuits, TRDSport10 and 3 others like this.
  14. Mar 3, 2021 at 2:53 PM
    DarthPow
    unfortunately my truck does not have its original owners manual. But ill see if it says anything in the digital one I have saved somewhere.
  15. Mar 3, 2021 at 2:54 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    All trucks with the A750 trans (that includes V6 Tacos from 05-15) have overdrive. I think your confusion is in what overdrive is. It’s just a ratio numerically smaller than 1.00:1.00.
    Edit: 5th gear is OD in your case
    Edit 2: that’s why I hate the saying “sending sth into overdrive...” it makes RPM drop... clearly propagated by the clueless, lol
  16. Mar 3, 2021 at 2:54 PM
    gotoman1969
    Well you never stated your reason for being in 4. Why are you driving in 4? Yes if it’s hilly and you don’t want the down shifting I can see it. Again why are driving in 4?
  17. Mar 3, 2021 at 2:56 PM
    DarthPow
    oh got it. so just having it D lets it go into an overdrive gear? I thought it was a special button or something like I've seen on other trucks, that I just hadn't noticed on my truck or was a feature I was missing out on. lol
    Gunshot-6A likes this.
  18. Mar 3, 2021 at 2:59 PM
    verynearlypure
    Ernest
    The Buckeye State
    Hilly Ohio. I use 4 to engine brake sometimes depending on circumstances then bump back into over drive when sufficient.
    lynyrd3, Larzzzz and Accipiter13 like this.
  19. Mar 3, 2021 at 3:00 PM
    TnShooter
    Deogee
    STOCK
    D is Overdrive
    The converter can lock up partially to fully in gears 3,4,5.
    I find 4th gear is well suited for hilly terrain.
    lynyrd3, Biscuits, TRDSport10 and 3 others like this.
  20. Mar 3, 2021 at 3:01 PM
    TireFire
    Olympic Peninsula
    Yes. Putting it in 4 will lock the trans out of OD.
    DarthPow[QUOTED] and TnShooter like this.
