How do you stop rattling from speakers in the back?
Discussion in '1st Gen. Tacomas (1995-2004)' started by gottalovetacos, Nov 12, 2011.
  1. Nov 12, 2011 at 11:57 AM
    gottalovetacos
    gottalovetacos [OP] Member
    Erick
    Mission Viejo
    Prerunner
    I have kicker ds series in the back and polkaudios in the front...if anyone knows some tricks to stop rattling let me know!:)
  2. Nov 12, 2011 at 11:58 AM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    dynamat. new speakers.
  3. Nov 12, 2011 at 12:00 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    duct tape
  4. Nov 12, 2011 at 12:12 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    I dynamat extremed everything accept behind my dash. The doors, ceiling, floors, everything got the dynamat. I then put 1/4" thick foam inbetween the dynamat and the interior, it's hard to put back together with all the crap but worth it. Just doing your problem areas like this will get rid of the rattles. Regular dynamat will work fine.
  5. Nov 14, 2011 at 2:42 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    What kind of rattling? You shouldn't need something like Dynamat unless you have subs. Mounted speakers aren't built to put out rattling bass. If they are, you should probably turn the bass down if you don't want to blow them.
    Are the speakers screwed in securely?
  6. Nov 14, 2011 at 2:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Im guessing "Turn the fucking bass down" is not the answer youre looking for?
  7. Nov 14, 2011 at 3:01 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    X2
