How do you test for spark
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tree56, Jun 19, 2021.
  1. Jun 19, 2021 at 5:37 PM
    Tree56
    Tree56 [OP] Active Member
    2001 Tacoma TRD
    So, truck started this morning drive it 5 miles, stopped when food shopping. Tried to start truck, it would crank, but not start. Removed vacuum hose from brake booster to intake and sprayed starting fluid into intake, but would not start. Must be no spark! So how do I test for spark with these coil packs? Thanks, any help would be great.
  2. Jun 19, 2021 at 5:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Remove the coil and the plug. Leave the coil plugged in.
    Stick plug into the coil, then the end of the plug on the block. (Or any surface that’s grounded to the block.)
    ToyoTaco25 likes this.
  3. Jun 19, 2021 at 5:44 PM
    Tree56
    2001 Tacoma TRD
    Ok, I’m old school and I thought of that way, but I didn’t know if you could do it with a multi-meter. And if there is no spark, where do I go from there.
  4. Jun 19, 2021 at 5:47 PM
    TnShooter
    Deogee
    STOCK
    You could check for power to the coil.
    But not spark. Pretty sure the ECM sends the signal for spark. I don’t have access to a manual currently. If no one else helps. I will look and see what wire you need to check for power to the coil.
  5. Jun 19, 2021 at 5:54 PM
    TnShooter
    Deogee
    STOCK
    Turn the ignition switch On.
    Then check the Black/Red wire on the coil for power.
    If not, check the 30A AM2 fuse. (It’s probably good)
    This doesn’t check spark, only power to the coil.
    The ECM grounds the coil to generate spark.
  6. Jun 19, 2021 at 6:00 PM
    Tree56
    2001 Tacoma TRD
    Ok, just take a test lamp, stick the point into the red and then black to see if it lites up. If not check the 30 amp Am2 fuse to see if it is blown. Thanks, I’m just trying to understand.
    TnShooter likes this.
  7. Jun 19, 2021 at 6:02 PM
    TnShooter
    Deogee
    STOCK
    I would unplug the coil. Then check the connector.
    I don’t like piercing wires if I don’t have to.
  8. Jun 19, 2021 at 6:06 PM
    Tree56
    2001 Tacoma TRD
    I had the truck towed back home this afternoon, I just went out, 5 hrs later and it started right up. What is going on, when it is hot, up to operation temp, it will not start. What could I be looking for? Any ideas? I had it do this 2 times, and had it towed 2 times!
  9. Jun 19, 2021 at 6:09 PM
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    Most likely a bad starter or a bad ground. Or both.
  10. Jun 19, 2021 at 6:09 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Any codes? Does it crank?
  11. Jun 19, 2021 at 6:11 PM
    Tree56
    2001 Tacoma TRD
    Thanks, but it cranks just fine, but will not fire and start, I do not believe it is the starter.
  12. Jun 19, 2021 at 6:13 PM
    Tree56
    2001 Tacoma TRD
    No check engine lite, but I do not have a tester to read any codes. I could bring it to auto zone and have them check, but once I shut it down when it is hot, I have no confidence it will start again.
  13. Jun 19, 2021 at 6:33 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Cam or crank sensor? As someone mentioned earlier the ecm grounds the coils… I’m assuming you have a six…If you plan on keeping this truck invest in a decent scanner. Best 150 you can spend.
  14. Jun 19, 2021 at 6:35 PM
    Tree56
    2001 Tacoma TRD
    I have 3.4, but if it is the crank sensor, why start when cold and not start when hot?
  15. Jun 19, 2021 at 6:39 PM
    Tree56
    2001 Tacoma TRD
    Hey Rachelsdaddy, I see your from southern nh, I live here in Florida, but grew up and have a home in lee, nh, thanks for your help
  16. Jun 19, 2021 at 6:43 PM
    Tree56
    2001 Tacoma TRD
    Really frustrating problem, when it’s cold it starts, drive it 5 miles shut it off, try to start it, it cranks great but will not fire and start. Tried starting fluid in intake and still will not start. The first time it died it was the EFI relay, put a new one in, started right up, but when hot won’t start. I’ve had to get it towed twice.
  17. Jun 19, 2021 at 6:56 PM
    Rachelsdaddy
    Southern NH
    That is absolutely the worst.. much rather it crap out good just once. Without looking at a schematic I would assume that either a faulty knock , crank or cam sensor would prohibit ignition. Electronics, sensors and connections are can be temperature sensitive. I have a twerpy 2.7. Wish I could be more help. Buy a scanner. Thank me later. Over and out. Hooksett
  18. Jun 19, 2021 at 6:57 PM
    Tree56
    2001 Tacoma TRD
    Thanks for your help, have a great fathers day
  19. Jun 20, 2021 at 7:15 AM
    Tree56
    2001 Tacoma TRD
    Hey guys, I think I found my problem, it was a loose igniter connection! Thanks for all your help.
  20. Jun 20, 2021 at 7:24 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Multimeter is too slow. They typically work on an averaging type read out, specifically Root Mean Square (RMS).
    Multimeter won't work.
