How do you torque the top bolts for the strut?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Raul4431, Sep 30, 2022.
  1. Sep 30, 2022 at 4:24 PM
    Raul4431
    Raul4431 [OP] Active Member
    Raul
    Concord, NC
    2021 Black Tacoma TRD PRO
    Question for all you DIYers. How did you tighten the top bolts to proper torque? Is there a tool I'm missing out on? Or are we talking about using that elbow grease? Please let me know. Going to be installing a Westcottdesigns TRD Pro lift kit soon.
  2. Sep 30, 2022 at 4:30 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I can get a torque wrench on 2 of them with a shorty socket. The 3rd one is impossible. I just snug them up real good and check again after 100 miles or so.
    33yrsoftoys and Raul4431[OP] like this.
  3. Sep 30, 2022 at 4:31 PM
    tcjacado
    tcjacado Well-Known Member
    Elbow grease or get a crows foot that fits the bolt and attaches to the torquewrench.. Just don't compress/ crush the bushing beyond the washer.
    Raul4431[OP] likes this.
  4. Sep 30, 2022 at 4:31 PM
    Bishop84
    Bishop84 Well-Known Member
    The nuts to the truck? or the single nut on the shock rod?
    I use a long 14mm wrench. Elbow grease. They easily get dirty so I use very little lubricant on them. It's not a bad idea to re-tighten them after a few days.
    The shock rod nut I just crush the bushing until it bows like it did before.
  5. Sep 30, 2022 at 4:32 PM
    Raul4431
    Raul
    Concord, NC
    Okay good that third one was the one I was most concerned about! I didn't know if anyone had some sort of trick on getting it torqued.
  6. Sep 30, 2022 at 4:34 PM
    Raul4431
    Raul
    Concord, NC
    Not the single nut but the one that sits furthest away from the wheel well.
  7. Sep 30, 2022 at 4:34 PM
    LoMa
    LoMa Well-Known Member
    2016 Tacoma TRD Sport AT MGM
    Same here. The last one goes on German tight.
  8. Sep 30, 2022 at 4:39 PM
    Raul4431
    Raul
    Concord, NC
    Yall ever try a crows foot? Like Jacado mentioned earlier?
    wilcam47 likes this.
  9. Sep 30, 2022 at 4:49 PM
    LoMa
    I thought about it, but I didn't want to buy a set of tools I'll barely use. I just add it to my list of things to check during regular maintenance.
  10. Sep 30, 2022 at 4:49 PM
    tcjacado
    I never tried it, its just the proper tool.
    I have always used the German method :hattip:
    Superdave1.0 likes this.
  11. Sep 30, 2022 at 4:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’ll have to run out and see if you can get a crows foot on it.
    But it seems like it would be too short, and if it’s not lined up right, and open end might not work.
    I ordered a 17mm torque extension when I did my hubs. (12 point boxed end)
    Worked great.
    tcjacado[QUOTED] likes this.
  12. Sep 30, 2022 at 5:10 PM
    TnShooter
    Deogee
    STOCK
    And No, I didn’t reduce the torque like you “should”.
    Before someone mentions it. :rofl:
    tcjacado likes this.
  13. Sep 30, 2022 at 5:18 PM
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    I need to install the same kit...I'm mostly wondering when I know when to stop tightening...like do I could the visible threads and stop after a couple?
  14. Sep 30, 2022 at 5:19 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    ‘Get a cheap set from Harbor Freight. You don’t use them much.
  15. Sep 30, 2022 at 5:31 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I just used a box end wrench on that one. I think a crow's foot will alter the torque reading anyways.
  16. Sep 30, 2022 at 5:37 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Don't sweat about. Torque by hand and put a mark on the side. Put a 1/4 turn after a few miles. It wont go anywhere
    Raul4431[QUOTED][OP] likes this.
  17. Sep 30, 2022 at 5:43 PM
    Tacodog
    Tacodog Well-Known Member
    Ron
    Renton, Wa.
    ‘19 TRD offroad DCSB Cement
    Icon stage 1, Icon upper control arms, 17” Fuel wheels,Ridge Grapplers, TRD exhaust, leather interior.
    Can torque front bolts. Measure exposed bolt. Match third to it.
    Koolbreeze7 likes this.
