How Do You Use A Grease Gun?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WATacoRider, Mar 3, 2010.
  1. Mar 3, 2010 at 4:15 PM
    WATacoRider
    WATacoRider [OP] Well-Known Member
    TRD Sport 4x4
    I wanted to grease up my drive shaft zerks. So I went to AutoZone and bought a grease gun and tube of grease.
    I cant seem to get grease out of the gun.... I've been pumping for the last 10 mins and nothing comes out.
    Both sides of the grease tube is removed. I inserted it in the right direction. The end with a lip, is up on top.
    The only thing I'm not so sure about is, if the plunger handle is suppose to compress all the way to the base of the tube body.
    My plunger handle is in the closed position like this pic, with the tube of grease inside it.
  2. Mar 3, 2010 at 4:17 PM
    scocar
    scocar hypotenoper
    Did you twist open the nozzle at the end of the hose?
  3. Mar 3, 2010 at 4:21 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    did you apply pressure from that silver thingy at the bottom. i think you gotta put the tub in, push up on that silver T at the bottom to get there to be some pressure then squeeze
  4. Mar 3, 2010 at 4:24 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    its air locked!!! alright pull the handle all the way out Do not tighten the tube all the way push the handle back in while pumping when grease comes out Then tighen the tube and then you should be good to go or Read the Directions should tell you the same thing
  5. Mar 3, 2010 at 4:24 PM
    Taco93
    Taco93 Well-Known Member
    Milton, Ontario
    2011 TRD Sport
    Extang Trifecta Tonneau, Weathertech Floor Liners
    The plunger on my gun is spring loaded, I pull it out all the way, insert the tube of grease, screw the head back on the gun and release the spring so the plunger applies pressure to the grease in the tube, once you start squeezing the handle the grease starts to flow.
  6. Mar 3, 2010 at 4:26 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
  7. Mar 3, 2010 at 4:26 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I remember when I first loaded my grease gun, I had to unscrew a "bleeder nut" on the lever end of the gun to release the air, before I could pump grease out of the hose. If you do the same, be aware that grease will pour out, as it's under pressure from the spring inside the cartridge housing.
  8. Mar 3, 2010 at 4:27 PM
    DeathBound
    DeathBound Well-Known Member
    Jay
    Mississippi Gulf Coast
    2010 Tacoma SR5 4X4
    In the 1st picture it shows a button, that's to release the air. But the second picture doesn't show it. So which do you have?
  9. Mar 3, 2010 at 4:32 PM
    WATacoRider
    TRD Sport 4x4
    if i dont tighten the pump all the way down at the beginning, it wont screw on. Keeps popping out....
  10. Mar 3, 2010 at 4:32 PM
    WATacoRider
    TRD Sport 4x4
    PS, there is NO manual to read.
  11. Mar 3, 2010 at 4:33 PM
    WATacoRider
    TRD Sport 4x4
    I have the 1st one. The 2nd pic was just showing the position of my plunger.
  12. Mar 3, 2010 at 4:36 PM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    The plunger should be all the way out with a new tube of grease. It gradually closes in when the grease is being used.
    1. Unscrew the head of the grease gun from the barrel by twisting it counterclockwise.
    2. Pull out on the spring-loaded rod handle at the bottom of the gun and lock the notch in the rod into the detent at the base of the barrel.
    3. Remove the bottom end cap from the new cartridge and push the cartridge completely into the barrel, open end down. Use the pull tab to remove the top seal from the grease cartridge.
    4. Screw the head onto the barrel loosely. Release the rod handle from the bottom of the barrel and push on it lightly to remove trapped air.
    5. Finish tightening the grease gun head on the barrel. Press the bleeder valve on the head to release any remaining air.
    6. Depress the lever repeatedly until the grease flows out of the hose or coupler, fitting smoothly.
  13. Mar 3, 2010 at 4:36 PM
    DeathBound
    Jay
    2010 Tacoma SR5 4X4
    The button should release the trapped air. You got to play with them sometimes. Try holding it upright, push the button, release, pump, repeat. They are a pain.
  14. Mar 3, 2010 at 4:40 PM
    jandrews
    '09 FourDubDee TRD OR
  15. Mar 3, 2010 at 4:40 PM
    Celtic
    Celtic Tactical Trunk Monkey
    Nick
    McKinleyville, CA
    In the market for V6, 6MT 4X4
    Sold my 2006 V6 6MT AC Offroad like an idiot.
    The button is on the top, of the grease gun, sticking up with the little spring around it. That is the air bleeder. FYI :D
  16. Mar 3, 2010 at 4:44 PM
    bigyetti
    bigyetti Well-Known Member
    mike
    asheville, nc
    08 taco dc 4x4 short bed
    sirius satilite radio, more on the way when i get more money. oh ya removed the secondary filter
    Use a bigger hammer. lol
  17. Mar 3, 2010 at 4:44 PM
    DeathBound
    Jay
    2010 Tacoma SR5 4X4
    Sorry for not being more clear..^^
  18. Mar 3, 2010 at 4:49 PM
    WATacoRider
    TRD Sport 4x4
    I think I got a pump with bad screw threading. I cant screw the pump down all the way with the grease tube inside.
    If I remove the grease tube, the pump will screw all the way down and secure.
    With the grease tube, the pump is about 2MM out of position and and loose.....
  19. Mar 3, 2010 at 4:50 PM
    DeathBound
    Jay
    2010 Tacoma SR5 4X4
    did you pull the cap off the grease tube? not trying to make you look stupid....been done before.
  20. Mar 3, 2010 at 4:52 PM
    WATacoRider
    TRD Sport 4x4
    lol yes, both ends of the tube of grease is exposed.
    Hell, I might just scoop the grease out of the tube and pack it inside the grease gun....
    But hell, I paid $30 for this gun, I want it to work the way it's suppose to. :(
