How do you wire speakers and tweeters off of a 2 channel amp?
Discussion in 'Audio & Video' started by CUtigerfan, Aug 3, 2010.
  1. Aug 3, 2010 at 2:32 PM
    CUtigerfan
    CUtigerfan [OP] Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    i'm just gonna send the tweeters back. i was on ncttora trying to figure out how to pull panels out and found a diagram showing rear speakers in a regular cab. was that a factory option for 01-04. heres a link.
  2. Aug 3, 2010 at 2:47 PM
    Daudio
    Daudio Well-Known Member
    North Jersey
    '02 SR5
    avic-d1 sirius tuner Ipod adapter
    It's very possible that the tweeters have a built in filter on them, most after market tweeters do. If they do you don't need anything else but to wire the amp at the correct ohm load.
  3. Aug 3, 2010 at 2:48 PM
    Daudio
    North Jersey
    '02 SR5
    No rear speakers in a first gen regular cab
  4. Aug 3, 2010 at 2:50 PM
    Daudio
    North Jersey
    '02 SR5
    You can wire the tweeters in series if there is a filter and you're good to go. You're best bet however would be to return all of it and just go with a component set up. You should be able to find something in the price range of what you've already spent
  5. Dec 8, 2010 at 6:40 PM
    CUtigerfan
    South Carolina
    04 Base
    Time to bump up an old thread. I ended up hooking up the coaxial Orions to the amp and disconnecting the factory tweeters connections so all thats running are the Orions in the lower part of the door. Problem is I'm hurting for base bad. I found an inexpensive box, sub, and amp package that I'm sure is not top quality but its really all I can afford right now. Can someone tell me how to wire this into the setup I already have? I've heard something about a distributor block but don't know anything about them.
    Here's a link.
    http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/7737303/vpcsid/11568821/SFV/30046?utm_source=google&utm_medium=base&utm_campaign=GoogleBaseFeed
  6. Dec 8, 2010 at 8:09 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    It comes with a wiring kit so just install it like the instructions that are included say to.
  7. Dec 8, 2010 at 9:03 PM
    CUtigerfan
    South Carolina
    04 Base
    But how do I integrate it with the amp I already have? I'm guessing it says to plug it into the back of the headunit. Don't I need something to split the power and signal between the amp going to the speakers and the one with the sub?
  8. Dec 9, 2010 at 6:13 AM
    dolbytone
    South Carolina
    09 TRD Off Road
    You don't integrate it, run separate power, maybe ground in the same spot. The inputs looked like speaker level inputs in the picture so you could go from the output of your amp, but you'll have to wait until you get it to be sure hence...
  9. Dec 9, 2010 at 11:29 AM
    CUtigerfan
    South Carolina
    04 Base
    My question is wouldn't the install kit tell me to connect the sub's amp and the headunit using RCA cables? I already ran RCA cables from the headunit to the amp I have now. Do headunits have 2 sets of RCA plugins? If not what do I do?
  10. Dec 9, 2010 at 1:03 PM
    dolbytone
    South Carolina
    09 TRD Off Road
    All I saw was speaker level inputs hence
  11. Dec 9, 2010 at 1:18 PM
    CUtigerfan
    South Carolina
    04 Base
    I'm really sorry but I don't understand what your saying.. could you dumb it down a little more for me.
  12. Dec 9, 2010 at 3:25 PM
    dolbytone
    South Carolina
    09 TRD Off Road
    What I am saying is you can't know what to do until you get it and see what options you have.
  13. Sep 8, 2021 at 9:46 AM
    mason33x
    mason33x Well-Known Member
    Mason
    2009 Tacoma 2.7 regular cab
    k&n filter , cherry bomb muffler , 2/3 drop
    Would 4 tweeters and 2 speakers sound good
  14. Sep 8, 2021 at 10:17 AM
    dolbytone
    South Carolina
    09 TRD Off Road
    no
