How does a TSB WORK
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shemicals, Feb 11, 2011.
  1. Feb 11, 2011 at 3:18 PM
    Shemicals
    Shemicals [OP] Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    So I feel I have an issue with the vibrating drivetain at 2.5 rpms. How does the TSB work. Is it free to fix? How do I prevent them from performing certain tsbs like the gas pedal deal
  2. Feb 11, 2011 at 3:24 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The gas pedal fix is not a TSB, it's a safety recall. A TSB does not apply to all vehicles, you have to prove to the dealership you need the work done for a specific problem in order them to perform a TSB. A safety recall is automatic, you'd have to specifically tell the dealer you to NOT want that work done and would have to sign a waiver.
  3. Feb 11, 2011 at 4:02 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    A tsb is just what the name implies. Toyota techs figure out that a complaint is due to a problem that can be fixed in a certain way. It gets submitted so othe techs can address the problem without having to troubleshoot. Unfortunatly for them people get wind of them and look for problems instead of actually having them... See spring tsb...
  4. Feb 11, 2011 at 4:05 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    It's basically and unpublished recall. They only perform the repair if you complain about it. They don't tell everyone it exists. Most people find out about them through boards like this.
  5. Feb 11, 2011 at 4:45 PM
    island808
    Jedediah
    hawaii
    No not at all. Some may be so frequent and irritating that they seem that way, but first, a recall must be a safety issue, and second, they have TSBs on anything that needs doing frequently, be it changing oil or re-soldering something that might be hard to do or diagnose. Things like the rear spring TSB that actually requires a part that MAY not be quite up to some customer expectations. Fixing things that are maybe annoying to some, may happen to some, may fail earlier than typically acceptable. Published by the company, but often come from the technicians initially. They can be as simple as "it is important to torque the oil drain plug exactly to specs or it will leak"
    It should be just part of their repair reference library, but people hunt down the problems and try to get the TSBs done regardless of need, then get all pissed off when the dealer tries to protect toyota's money from frivolous warranty service. I don't know if toyota did it, but we were prone to warranty inspections. THe dealer had to keep the warranted parts to show that they did the work they charged toyota for. That's why you generally don't get your parts back on warranty work.
  6. Feb 11, 2011 at 5:32 PM
    Shemicals
    Build Page
    So if my warranty is up I cannot get the work done?
  7. Feb 11, 2011 at 5:52 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    There may be better options that cost less if you are out of warranty...but you can get the TSB work done on your own dime. And it never hurts to ask for it and make they tell you no...
  8. Feb 11, 2011 at 6:52 PM
    island808
    Jedediah
    hawaii
    You just have to pay for it. A tsb is just a way of fixing a problem.. an addendum to the service manual. If its under warranty it warranted regardless if its stated in a bulletin or in normal shop manual.
    Some things are such a concern that they'll extend warranty on just that item to save their reputation, make you happy. But that's fairly rare.
