How does odometer and trip meter retain mileage with no battery.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spitdog, Dec 23, 2020.
  1. Dec 23, 2020 at 10:55 AM
    spitdog
    spitdog [OP] Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    So when I replace my battery and there’s no juice to power the ecu, how does this effect the odometer, trip mileage meter, and 5000 mile maintenance.
    Does the odometer have some back up energy source?
  2. Dec 23, 2020 at 10:58 AM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Flash memory chips im assuming:notsure:
  3. Dec 23, 2020 at 11:17 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    In a nut shell:
    Non-volatile memory
    Non-volatile memory (NVM) is a type of computer memory that has the capability to hold saved data even if the power is turned off. Unlike volatile memory, NVM does not require its memory data to be periodically refreshed. It is commonly used for secondary storage or long-term consistent storage.
    Probably EEPROMS
    https://en.wikipedia.org/wiki/EEPROM
    Dm93, spitdog[OP] and replica9000 like this.
  4. Dec 23, 2020 at 11:21 AM
    spitdog
    Thanks Jimmy, and I can honestly say I never heard of Non-volatile memory until today. :thumbsup:
  5. Dec 23, 2020 at 11:23 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ODO will obiviously not reset
    trip will.
    spitdog[OP] likes this.
  6. Dec 23, 2020 at 11:34 AM
    Jimmyh
    SC
    2012 Prerunner SR5
  7. Dec 23, 2020 at 11:40 AM
    spitdog
    Well I can imagine how a glitch could really effect the resale of someone’s vehicle if it put an extra 200 thousand miles on the odometer or erased it completely.
  8. Dec 23, 2020 at 11:47 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Or took off 100K Miles... ;)
    Many years ago I know "a guy" that leased a vehicle and it had a clause for annual mileage limit or he would have to pay a huge price per mile. Had the old mechanical odometer. Go in with a set of rubber gloves and a set of jewelers screwdrivers... Boom 40K miles removed in less that 30 minutes.
    :thumbsup:
    spitdog[QUOTED][OP] likes this.
  9. Dec 23, 2020 at 1:21 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    One of my cars lost 20K miles when I swapped the instrument cluster from another car. At the time I want trying to roll back miles, just needed a speedometer with a higher limit.
  10. Dec 23, 2020 at 1:40 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Just put the truck on blocks and run it in reverse to roll back the mileage. duh.
    jfoster92, TegoTaco and nd4spdbh like this.
  11. Dec 23, 2020 at 1:49 PM
    AustinMada
    AustinMada Thinking About Tacos
    WA.
    19 DCSB OR
    This actually works on 2018s and below.
  12. Dec 23, 2020 at 3:50 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    the older super duties retain there mileage in the dash cluster instead of the ECM, and the truck doesn’t need the cluster to run. so many hot shotters just remove the cluster and drive thousands of miles cross country and when they go to sell the truck reinstall or find a cluster from a lower mileage truck. So on those type trucks when they have such “low mileage”, there are other things to check such as steering wheel wear, seat wear, drivetrain condition, etc to determine if you’re getting false mileage reported. If a deal seems to good to be true, it probably is.
    Pickeledpigsfeet likes this.
  13. Dec 23, 2020 at 3:53 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    So it's not magic fairy farts? You people have utterly ruined this for me
    :pout:
    Jimmyh, Hobbs and 6 gearT444E like this.
  14. Dec 23, 2020 at 4:01 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    Older mechanical odometers were super easy to “adjust”. I had to rebuild a few for my old Mercedes and Buick Roadmasters. Set the mileage to where it was and not lower than it was supposed to be but it’s easily done
    Jimmyh[QUOTED] likes this.
  15. Dec 23, 2020 at 4:12 PM
    replica9000
    2019 T4R ORP
    I'm not sure how Toyota does it. I know GM stored the mileage in the odo and the ecu as well. With one of my cars, neither was the original. I also drove the car without the cluster for a few days. My caddy on the other hand wouldn't even turn over if the cluster wasn't 100% working.
  16. Dec 23, 2020 at 8:37 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No, it doesn't. I know a guy that tried doing that with a drill on the speedometer cable and he found out that the odometer is clutched and only works in the incremental direction. That was on a 1985 Toyota with a mechanical odometer.
    It certainly will not work with an electronic odometer. The wheel sensors know which direction they are turning.
    6 gearT444E likes this.
  17. Dec 23, 2020 at 8:44 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I believe they generate a pulsed voltage, which is the same regardless of direction of wheel travel, so going in reverse would still add up mileage. The speedometer does not go negative when you drive in reverse, but I never checked the odometer to see if it tacks on miles as you drive in reverse for a significant distance.
  18. Dec 23, 2020 at 9:04 PM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
  19. Dec 23, 2020 at 9:14 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    some call it magic, I’d call it magnetism. Invented many moons ago.
  20. Dec 23, 2020 at 9:18 PM
    wiggler
    HILO
    ok, let me clarify:
    JustJon and 6 gearT444E[QUOTED] like this.
